Evo3 Big 16G, what psi?
eclipsegst3131
Banned Member
219
Jun 5, 2004
Manchester, New Hampshire
currently i have a fully rebuilt motor, only has a cometic head gasket and eliminated balance shafts. i have an injen intake, greaddy ic pipes and rs bov, full 3" exhaust and an evo 3 b16g turbo. question is, how much psi should i be running with the stock fuel pump and injectors 'safely'. i want to do injectors obviously, what size should i get, i'm looking at making about 320whp. also, im getting a walbro fuel 190 fuel pump. what psi would i be able to run when i get the fuel upgrades in, and is there anything else i should do? thanks for any and all help!
how about you get a logger and see when/if the car knocks :thumb: :boring:
LOL, cuz i'm cheap...i need one i know, but how much could i run with the fuel mods i've done, or how much has anyone heard of people running. thanks for any help. :thumb:
evo3, stock injectors, 190lph, no logger = 15psi good game. Still 10x better than a t-25@15psi
when u get a logger and check knocks/timing, then maybe u can go up.
Hey man, bottom line is you got some sweet gear under that hood . . . don't ruin your week/month by blowing a head gasket or w/e
You shouldnt have upgraded turbos if you are to "cheap" to get a logger. Things arent gonna be cheap when the engine starts detonating.
I run 18 all day (miost a 1G BOV will take) and Im fine. I have 550 cc injectors though. Everything else is completly stock. And I get no knock!
I am using only 14lbs. 298whp/281tq
I've got the SAFC, 550inj., 255lph walbro.stock fpr
You should definetly go with the higher flowing pump (opinion) to make sure you're adequately pumping enough. I know a lot of people say "it's okay, it flows more then enough" Just a little added security.
  • For sale 1g 1G 4 Bolt LSD Rear Axle Set
    1G 4 Bolt LSD Axle Set $120 + shipping & paypal feesYou must be registered to see...
  • For sale 4G63 1g/2g Auto Welded Center Diff
    1g/2g Auto Welded Center Diff. Message 702-741-6987.
  • For sale 4G63 6 Bolt ARP Head Studs
    ARP 6 Bolt ARP Head Studs $65 + shipping & paypal fees* these have been torqued onceYou must...
  • Wanted 2ga side markers
    Looking for 2ga side markers
    • Rohitter7878
