What could cause this wear. Pic inside
96Formula6spd
245
22
Nov 17, 2009
Greenville, South Carolina
Hey guys my car been running bad for a couple of days anways took it to the shop and we narrowed it down the a coil pack. Anyways got back today and was going to make a video of the miss fire. Started it up and it sounded real bad on the timing belt side. So I pulled the timing cover to find this.
As you can see there is a groove about a millimeter thick and about a centimeter wide. The timing belt was done about two weeks ago when I had to replace the oil pump seal. So what could cause this?
same thing happened to me once and just like the others said, its one of the oil pan bolts. Your misfire is probably due to all that oil you have on your valve cover. You more than likely have some down your spark plug wells. Please give your car a good tuneup.
That's a Contitech AG belt ..... Contitech is the OEM supplier for Mercedes Benz, Volvo, BMW Audi, Mitsubishi and a few others..
But true - get that thing back to the shop that did this work and get this matter fixed pronto for that groove is creating a horrible weak spot in the belt now...
Yep car is getting towed to the shop next week. Getting a new oem belt and fixing the bolt. Then time to sell the car for something more reliable. This has not been the only problems out of it.
