what can i use form my 6-bolt for a 16G setup?
NvDiS
144
Nov 25, 2010
Miami, Florida
i have a complete 6 bolt motor with everything!!(turbo, intake mani VC to oilpan etc.) i was wondering what could i swap from that motor to my 7 bolt to run a 16g..but just was curious thanks!
The only thing you could use as a direct bolt on upgrade to a 1g motor is a 2g head..Unless you plan on porting the 1g head..Also theres the 2g pistons, and 2g maf, if you have an safc and larger injectors..
Also in your profile..Will you add, what clutch, fmic kit, and what bov..
Do you still have a stock intercooler? Either way you will need the "J" pipe IC piping to mount to your IC. There are two types depending if you have a stock IC or a FMIC. You will also need to modify the oil return line ("J" pipe) to bolt on to the turbo. When i had this setup on my 2g I just used a dremel to oval out the oil return flange that bolts to the turbo. Everything else is pretty much a bolt on. Hope this helped.
done. Dont know what front mount it is because i bought it with the car previous owner didn't say
so why is it that vendors sell an install kit? I thought that this wasnt a direct bolt on for the 2gens but it was for the 1st gen
Sorry for the cunfusion. Its not a direct bolt on, but it is a bolt on turbo meaning you can use your stock manifold to bolt on too. So it's not an exact bolt on. I don't think there is much else you can use from the 6 bolt.
