turbo rebuild
timsturbotalon
115
Nov 19, 2008
blacksburg, Virginia
i have a mhi evo 16g has a bit of shaft play. plan on rebuilding it. need to know how hard its is to rebuild a turbo, and where to get rebuild kit.
There is a parts review section on the forum and a search bar. Use it. If you did then you would have came across the thread detailing the rebuild kits from Greg on eCrater.
Also you would find the rebuild guide that Jusmx141 posted.
The rebuild isnt hard as long as you have the proper tools. No rebalance is required as long as you scribe the compressor wheel, shaft, and lock nut and put then back together the way they are marked.
