turbo confusion
And an oil return line unless you plan on modifying the one for the T25. Here's a picture of the T25 (left) against a 16G (right):
no its a 95 gst i just got it a few weeks ago and i havent changed my car thing yet sorry ill do it now
ok now i am really lost
now i see that some people just run the vacuum line from the housing to the waste gate and then i here people have turbo controlers and turbo timers
what do i need to do or get and what is the diff?
On an original setup, a vacuum line will connect the wastegate, the compressor housing, the boost control solenoid (the OEM method of measuring/controlling boost pressures), and likely some other lines.
Technically, you don't need any of it. But if you are looking to have a bit of fun, you can certainly look into a manual boost controller (your turbo controller). Everyone here knows that if you decide to install such a controller, you better install an aftermarket boost gauge as well since the original unit is not accurate at all for translating boost pressures. Steer clear of turbo timers; they are not necessary at all.
Before purchasing a manual boost controller, I suggest doing some reading to understand what is involved with boost control:
http://www.dsmtuners.com/forums/articles-turbo-system-intercooler/382016-basics-boost-control-wastegates-how-turn-up-boost.html
Then, if you choose to purchase a manual boost controller, I suggest reading here to find out the best method to installing it:
http://www.dsmtuners.com/forums/articles-turbo-system-intercooler/237982-best-way-install-mbc.html
