snowborder714
Moderator
- 16,188
- 465
- Oct 15, 2006
Mechanicsburg,
Pennsylvania
Why don't we take the redesigned strut tower convo to another thread?
Yup.
The pickup option is the inboard connection for the lower control arms and the toe arms. My kit has everything needed for installation. It uses spherical joints at every connection instead of bushings.
On a related note; I am also going to work on a bracket to raise the upper control arms. I'll hopefully have a prototype set finished and in use this spring or summer. I'd ideally like to raise the upper control arm 1" to match the lower.
Paul,
Just to clarify your post - Are you planning to incorporate an adjustment for the fore lower control arm inboard pickup on your tubluar front subframe? I'm interested in raising this pickup ~30mm, and would love to upgrade to a tubular subframe instead of modifying my current subframe.
Thanks.
I went over to SIM on Saturday and test fit it on John's Talon. I'll post more about it when I'm less hungover.
I wonder about improved airflow under the car... I mean the stock rear subframe is basically like a big air brake under the car. Air flow is forced around it. Can't get thru it. Now with these tubular subframes I'm sure there's some turbulence caused but not much to block air flow. I'm sure it's not a big deal but it's neat to think of.
I guess I mean this more for a car that has spare tire well eliminated
That was exactly what I was wondering about Tim. Rear bumper cover looks to be a pretty good air foil. On some cars like Andrew's and tsiawd666's car I see they have eliminated the bottom of the rear bumper cover while installing the extreme downforce body kit. Even without the bodykit I could see at the very least having to cut some air pressure relief holes Or raising the bottom lip a bit.
Don't you have that choice?
, but I still have to accept the fact that I would be chopping half of my car's ass off. The bumper and paint is so damn clean on my car I have a hard time doing it currently. I would rather get the diffuser made first, then cut the ass off. Then I can integrate the exhaust into the aero with a belly pan.
Yup. Although it would be cool to develop some sort of aftermarket strut tower to weld in place of the original for the guys that want to change the angle of the front upper arm. I imagine there would be a very small amount of people interested in doing that to their cars though.
Hmmm..... *wheels turning*
I believe the double wishbone trumps the mcpherson in terms of handling. Double wishbone rolls better and affords more opportunity for fine tuning. Having an upper control arm eliminates camber gain during compression, which a mcpherson does not. A better idea for improvement to the 2G front suspension would be an adjustable upper control arm.Hope this isn't too tangential. What about modifying (or replacing) the knuckle to go to a McStrut upper but keeping the lower double ball joints? My buddy Pagosa DSM mentioned BMWs do something like this. It'd sure make camber/caster adjustment easier and probably shed some weight. Not sure what it'd do to the suspension dynamics though...
I talked with Andrew Brilliant quite a bit about the front compression arm. In short, he says it would be a terrible idea to eliminate it being that the front corners experience both acceleration and braking loads.That or just go to a single ball joint, a longer a=arm, and longer axles for a wider stance (and wider tires). With the custom lower control arms in the rear you could do the same and get an overall wider footprint and more tire under the car.
