- Thread starter
- #301
99gst_racer
Moderator
- 12,010
- 1,706
- Apr 5, 2003
Coloma,
Michigan
Thanks guys!
No economy heims here. The heims I used have heat treated bodies and balls. The body is coated for corrosion resistance, and they are also teflon lined, so no need to lubricate them. I shopped around and compared various radial load capacities of several different models before I finally landed on these. And they are a large part of why the arms cost so much.
I have used the general purpose carbon steel heims before and I know what you mean about sloppy. They're loose when they're new and they wear out very fast in a stressed environment.
The LCAs and toe arms should be plenty strong as they sit. I used heavy wall tubing on both. Also keep in mind that each rear corner uses a trailing arm to do much of the work of keeping the wheel in place.Are you putting triangulation on the rear toe control, or do you think two tubes can handle the force? Not to nit pick just asking for safety purposes =)
Btw, those heim joints your using aren't cheapo ones are they? We get jeeps in the shop that have those same 1 1/4 or 1 1/2" balls and they get sloppy fast.
