- Thread starter
- #126
daren_p
DSM Wiseman
- 4,605
- 98
- Nov 22, 2004
Newmarket,
ON, Canada
Have you ran the turbo hard yet? What do you think so far? I 'm thinking about picking up either a 20g, Green, or 3052/3076.
What do you consider hard? For much of the summer I was running 22-23 psi daily with meth injection, seeing 17-18 deg advance by redline. At these levels it pulled very nicely & you wouldn't have trouble out running 99% of the other cars on the road (though I do not street race). Have also ran it at 25-26 psi at the track, again with meth injection an some NOS octane booster. It pulls nice & hard at these levels, my setup isn't geared to top end power but still see 42-43 lb/min by 6500 rpms, where my airflow flatlines. That was with a stock 2g intake mani & head with FP1X cams which are designed to make power in the 4000-6000 range. I'll be swapping to an evoIII intake mani this spring so hopefully this free's the topend abit. With a better flowing topend setup you will easily gain more then a couple lb/min at these levels. With the proper setup I don't see any problem seeing the 52 lb/min this turbo is rated for.....
) package.
I bet you guys are sick on the high way though. Dark Bulk your traction must be pretty retarded considering your 2.4 3052 set up. I bet those obese tires you have on there still break traction in 3rd gear.
