Starting issues - No / Doesn't / Won't Start - MERGED
prodsm
258
Nov 12, 2002
canada,
All "my car won't start" discussion threads are merged HERE. We've basically made it easier for those who insist upon not searching by grouping together all threads from those with similar issues so you can just scroll through and see some possible solutions. To search for info within this thread, use the "Search This Thread" feature in the black bar about 3" above what you're reading right now.
Could be anything from a loose battery terminal to internal engine damage, and literally everything in between which may involve the electrical, fuel, and ignition system...possibly even something that you screwed up while working on the car yourself. While it's unlikely we're going to diagnose and solve your problem over the internet, feel free to discuss any possible solutions.
I live in Canada and right now its not very warm out, about -30c
my car does not have a block heater too keep it warm.
I tryed to start my car this morning and it wouldent start, ive had this problem before but this time, the car doesnt crank at all it just makes a sound that sounds like an electric drill.
Whats wrong.
Thanks
I am working on a 1999 GST Spyder, replacing top and interior... only owned the car 6 weeks... its manual tranny.... replaced battery last week... car always starts fine. I started it is morning and let it run, took the convertible top down. Spend 5 hours working on interior, put in new carpet blah blah...
went to put top back up and stop for the day, and I always crank car and let it run a minute...well it wont start now... lights come on, top went up fine... but it wont crack... I hear a clicking in the dash, sounds like a relay... but nothing
Any thoughts?
Odd that this happened out of nowhere.
I searched threads and was reading about the clutch safety switch.... could that be the issue??
Yea. It could be the clutch safety switch. You probably should check that first....
Click from behind the radio
All fuses are good
It just died immediately
Starter shakes the whole car belts turn
And no check engine light
I work at Oriellys how do i know which ecu to get the system list about 10
I'm getting spark fuel and compression earlier my car is having problems starting one day when I went to wash my car it didn't want to start again my car was spraying oil on the wiring harness maybe that's whats causing the problem but not sure need help my car is a 95 gst
All these electronics usually won't work right after getting wet like washing the engine bay. Where is the oil coming out from make sure all sensors are plugged in. Double check it all.
Did you figure out where the oil was coming from?
Water got inside the spark plug wires.take them off and dry and the spark plugs and are your injectors pulsing if not check the coolant temp sensor
Do you have an open air filter and got that wet? Or a wet coil pack? You checked your spark, but was it a strong spark or a weak one? If it was running before you washed the motor, then it's something stupid. Let it dry out.
I didn't wash my Engine just the body and buffed out the carbon fiber hood and when I went to move my car it didn't start I thought it was because I was on a hill I backed my car up and it still didn't start
Oh I gotcha. Did it start up yet? Like said above, it could be the coolant sensor going bad. It's sending a false reading to the ecu and screwing with your fuel and ignition timing
How do you know your getting fuel? Or is it just injector pulse you have, what about fuel pressure? Is the pump actually working? Can you pull any codes from ecu?
I disconnected the fuel line from the fuel rail and I have my dad bring the key is pumping fuel I'm game if you want my combustion chamber 1 2 3 looks like four is a bit dry
