1G Starting problems (cranks, but usually doesn't start)
SweetEuthanasia
6
Apr 29, 2023
Halmstad, Ohio
Ok, I guess I wrote a bit too much before. So it's a 1g, on registration MITSUBISHI ECLIPSE I (D2_A) 2.0 i 16V (D22A, D27A) 1993 150Hk. I got it last year, running, driving and everything. Few months later it started having troubles starting or dying sometime on lower speeds. Local shop didn't understand anything, broke a few things, returned it in a worse condition. Engine cranks, sometimes starts - when it does, it runs well.
So, what could it be, where can or should I start and so on?
Do you have a way to monitor fuel pressure?
Is there spark when cranking? strong spark?
Speed density or MAF?
Be gentle - I'm very much a noobie. So, fuel - first if there is any - around the sparks, then if any filter is clogged with a cup - tomorrow I'm getting a socket for it and a tester. No ideas about the air pressure yet, since I'm working on a parking lot with a basic kit. I would mention that they supposedly have tested, supposedly the basic things and haven't found anything. I will ofc retest what I can again. I've also got a buzzer on the way for the ECU, which can be dead. Lastly, when i got it, and the whole time it ran, it had this small issue, when it would jump, lose power for a second, check engine, then come on - don't know if its related, didn't get any worse, just putting it out there. For the fuel pressure, assuming there is any, i guess ill get a tester..
Update 1 - replaced the fuse box on the battery - sadly with a homemade device, but it is what it is.
Car started and ran well after - I have a suspicion that tomorrow it wont, so ill do an ECU and a coolant temp sensor test and post the next results.
Will do and post updates after doing each and every step. Thanks a lot and lets hope we can get it on the road soon :3
Update 2: Tried the car again - starts on the dot, again - the weather is now warm and sunny, which might be affecting that, or the new fuse box.. Now the radiator hose (bottom left side, but further than the nose from the engine) decided to blow - or something else near by - water started coming out.
Update 3 - sort of. The car seems to be starting, the cooling system will need an overhaul, but Im considering towing it to a shop - different one this time. If it isnt too much to ask, I would like to know what to tell them to check there so the issue with the intermittent starting can possibly be resolved.
  • For sale 1g 1G AWD Engine Side Splash Shield
    1G AWD Engine Side Splash Shields $55 a piece + shipping & paypal fees* I don’t have any...
  • For sale 2g 2G OEM Cargo Net
    2G OEM Cargo Net $40 + shipping & paypal feesYou must be registered to see element.
  • For sale 2g 2G Auto Shifter Cable ( GSX/GST )
    2G Auto Shifter Cable $45 + shipping & paypal fees* GSX/GSTYou must be registered to see...
  • For sale 2g 2G Auto Shifter Base
    2G Auto Shifter Base $40 + shipping & paypal feesYou must be registered to see element.
  • For sale 1g Mishimoto radiator
    Mishimoto X-Line Aluminum Radiator | 1990-1994 1G DSM (MMRAD-ECL-90X)
    • william
