Starting issues - No / Doesn't / Won't Start - MERGED
prodsm
258
Nov 12, 2002
canada,
All "my car won't start" discussion threads are merged HERE. We've basically made it easier for those who insist upon not searching by grouping together all threads from those with similar issues so you can just scroll through and see some possible solutions. To search for info within this thread, use the "Search This Thread" feature in the black bar about 3" above what you're reading right now.
Could be anything from a loose battery terminal to internal engine damage, and literally everything in between which may involve the electrical, fuel, and ignition system...possibly even something that you screwed up while working on the car yourself. While it's unlikely we're going to diagnose and solve your problem over the internet, feel free to discuss any possible solutions.
I live in Canada and right now its not very warm out, about -30c
my car does not have a block heater too keep it warm.
I tryed to start my car this morning and it wouldent start, ive had this problem before but this time, the car doesnt crank at all it just makes a sound that sounds like an electric drill.
Whats wrong.
Thanks
All fuses under hood check out.
I did just hook up evo scan, turned pump on and it's good.
I read to check crank signal while cranking
Crank signal stays at 0
Iv read that's because I'm a 98 and they use cam sensor not a separate crank sensor not sure though.
So after reading few threads on here about what to test and pulling out the multi meter then testing OHMs all over the place. Everything tested fine, then hooked all plugs back up and charging battery it has spark and it fired up. Found 2 broken tabbs and I'm thinking it was a loose connection. But thanks for the moral support guys always helps.
So I just finished pulling the tranny and shimming the fork and now I go to start the engine and I get no cranking at all.
I hear the fuel pump going but the engine won't cranks
I checked the battery and I'm getting 12.5 volts
I checked the starter and I'm getting over 12 volts with the key in acc
The lights on the dash light up and I'm able to connect to dsm link.
I confirmed the signal wire is connected to the starter and the ground wire is connected to the starter bolt going through the bell housing.
I also checked for continuity from the battery negative to the starter negative and I get continuity.
The car started no problem before the swap and I disconnected the battery before touching the starter.
Any suggestions would be greatly appreciated.
Thanks
Brian
There is a one wire (black/yellow) connector that runs between the main engine harness and the starter harness. It is located behind and below the thermostat housing. It carries the start signal from the starter relay (under the dash) to the starter solenoid (on the starter). Here's a pic:
http://www.dsmtuners.com/threads/2g-engine-bay-electrical-connections.298047/page-2#post-151542290
Make sure that it's plugged in.
Jim
Wow I just found that connection and one side of the plug was missing the wire. I'll have to redo the connector but I'm sure this was the problem.
Thank you very much for your help!!
I am having a problem with my 92 Talon Tsi AWD. The car has 269000 miles and I recently had the head redone. When the car is cold (ambient air temp is irrelevant) it takes many tries before the car will run. It cranks over fine but just won't run. After several tries it will start to run but you have to keep the revs up until it warms up. Once warm everything works like it should. The check engine light is also on. I have changed the oxygen sensor, the idle speed control solenoid and the plugs are new as well as all the vacuum lines and pcv valve. The gas tank has been reworked and coated. The Walbro 190 fuel pump is new and has been rewired with large gauge wire. Timing equipment is all new as well as new radiator and all hoses. The only maintenance item that has not been replaced is the fuel filter as I cannot get the banjo bolt loose from the top. I am open to suggestions!!!! Thanks in advance for your help!
Well, I replaced the coolant temperature sensor with the correct Mitsubishi factory part and unfortunately, no change in the situation. Still hard to start when cold. If you keep cranking it over and pumping the gas it will finally fire off and if you keep it revving till warm it's fine after that. Car will sometimes backfire when cranking before it's warm. Anyone have any ideas?
Your thoughts are appreciated!!!!
Which sensor did you replace? there are three different sensors: one in radiator for fan relay, two in thermostat housing; one is a two pin style for the ecu, then a single wire spade connector style for the dash gauge.
The ecu is another good idea to check.
I will get some Royal Purple or Redline fuel system cleaner and give that a try. I will probably also take it to someone to get the fuel filter changed. I am just chicken to break the fuel line:D
Theres two devices on your car for idling 1. Isc motor 2. Fiav. Your problem sounds like fiav. Its either bad or theres air trapped in the coolant section of it. Try bleeding the air or swapping in another one. Its possible isc is bad but you would have idle problemd all the time not just cold. It should be removed/cleaned and checked for proper operation.
i thought this too at first, and i guess an air bubble could be to blame, but id expect it to have idle surge. i guess if its stuck closed or had an air bubble then it could cause the problem too. just didnt add up to a FIAV in my mind, but its a possibility.
since the proper coolant temp sensor was replaced, id start suspecting fuel pressure loss.
Have you tested your fuel pressure? When cold try to hot wire the fuel pump for a few seconds to build pressure. There is a small black connector next to the firewall. Do this at your own risk. Also, regarding the coolant temp sensor there is 2 that look alike. One is for the ac and the other is for the coolant temp for ecu. Make sure it's the lower one.
  • For sale 1g 1G AWD Engine Side Splash Shield
    1G AWD Engine Side Splash Shields $55 a piece + shipping & paypal fees* I don’t have any...
  • For sale 2g 2G OEM Cargo Net
    2G OEM Cargo Net $40 + shipping & paypal feesYou must be registered to see element.
  • For sale 2g 2G Auto Shifter Cable ( GSX/GST )
    2G Auto Shifter Cable $45 + shipping & paypal fees* GSX/GSTYou must be registered to see...
  • For sale 2g 2G Auto Shifter Base
    2G Auto Shifter Base $40 + shipping & paypal feesYou must be registered to see element.
  • For sale 1g Mishimoto radiator
    Mishimoto X-Line Aluminum Radiator | 1990-1994 1G DSM (MMRAD-ECL-90X)
    • william
