Products the DSM crowd would like to see made
Solid engine mounts. Instead of polyurethane replacements. Something that bolts on the engine mount, then the chassis. Hondas have these, and after riding in one the difference was night and day. I have seen a few people getting solid inserts for the front and rear mounts, but nothing for the tranny/engine mounts. Wouldn't be very daily driver friendly, but definitely helps traction.
I am currently designing new solid motor mounts. we have 1 set made currently. we are waiting on test results. these will become mass produced if all goes well.. price is approx 45.00 per mount. direct fit bolt on.
I want to see a front and /or rear diffusers
Taillights that aren't riced out, euros :barf:or just smoked(i like the smoked look but its over used)
clean body kits/ wide bodys that aren't riced out
other than that..I'm good i think:hmm:
Just to let you know guy's we have something called the Pro-Series line from Avid Racing. It's a completely solid aluminum engine mount kits. It's available for the DSM's and Evo's... :thumb:
Someone needs to make a projector kit for the 1gA. Something that just bolts in right where the headlight currently is. This way we can use HIDs and have
the proper beam pattern and cutoff. I bet a lot of people would buy.
For 2gs how about a way to adjust the rear camber on the bottom of the car instead of just buying some longer bolts and some washer for the top. My camber is still off bad. I believe the 1gs have some but not sure.
2gb Talon front lip PLEASE!! plain, simple and clean. nothing too fancy just something that adds a bit to it. I'm sick of trial and error with my own custom crap. as of now I'm working on a carbon splitter, but a lip would be nice.
I have to agree with this completely! The only heatshield that is currently out is the JM Fab heatshield, which while looking very good is the biggest PITA to install! How about making the bracket bolt together, and then have the heatshield bolt onto the bracket with a seperate mount.
I was wondering why I didn't see anything on their site. Any reason why they did? Some of the ones they had were really nice.
I live like 3 minutes from JMFab and my understanding is they were not selling too many of the heat shields. I'm sure if you call Jim up he will still make one but it may be slightly more expensive since now it is a "custom" job and not a typically produced product. I may be wrong though because he is a really nice guy and may just give you the same price. Call him up.
A DSM SHOE:
a shoe worn by the driver of a dsm owner with clutch problem pedal not coming back up to spec. The shoe will be worn on the left foot. The shoe will slip UNDER the clutch pedal, when the driver lifts his feet to shift gears the clutch pedal will return with the foot to make sure the clutch is full disengage.
I kill myself! THE GREATEST INVENTION EVER!
Any updates in regards to 1g (fwd ) traction bars? Also how about triangulated front and rear strut tower braces? Also anyone find any info on the 1g weather stripping? Dealer says "go f**k yourself" on those..
Functional Rear Diffuser
Functional Front Splitter that goes to cover under engine for better aero.
Widebody Front Fenders like the Evo guys get. (2g)
Carbon Fiber sunroof replacement that has one or two latches so it can be easily taken out.
Adjustable Sway Bar Endlinks
Bolt on ducting for front bumper to radiator (and people could buy and customize it themselves from there depending on particular setups)
Also the motor mount engine dampers
Bolt on 5mph bumper support for those running large fmics.
really good ideas, especially the widebody fenders like the evo guys get. :thumb: maybe some for the rear too?
JMFab already makes this.
No because the 2g's can be cut as it is just high density plastic.
Also, they already have carbon fiber wiper cowls out.
Also have door handles too, you are looking at like 90 a handle though for real carbon fiber.
I had to cut mine, but I doubt it's going to hold up to anything at all. I'd rather have a solid metal bar for the support and besides, it would be an easy replacement part for those of us with big FMICs. I would have bought one if they were made.
