Products the DSM crowd would like to see made
You may wish to check the classifieds/freelancer ads, sir. ;) Were my clutch not dying, I'd be on one right now.
Doesn't JM Fab still make a 1G front bumper support bracket?
EDIT: Yeah, here we go: 1G DSM Race Bumper
I clicked on the link and i had to reread your post. BUMPER SUPPORT BRACKET... by no means will this hold up in any front end collision. for $170.00 to get backed into by someone learning to parallel park... this product is a fail if you ask me.
id make you guys a sunroof cap, but i got a lot of work to do... let me get my car running first. then, if noone has done it, i'd need to find someone that needs it replaced for measurements and all.
1. English; speak it.
2. The race bumper isn't designed to hold up in a crash, it keeps the bumper from sagging. Your understanding of this concept "is a fail".
Notice the term "race". It's not being marketed toward street cars sitting in traffic.
Would love to see a CF hood with the "hump" on both sides.. haven't seen it mentioned yet so maybe even cut 2" off the front of each hump for air flow... I think
As the above member said, and as I've posted before, a carbon fiber cargo cover would be awesome. A full CF 1Ga wing would look sick too. From mirror to mirror. :D
75mm throttle body, rather than using Ford mustang TB's that leak all the time/or throttle shafts breaking. expensive option is the boomba which will cost over 500 bucks. <yikes>
Any word on tubular arms and such.
Would like to lose some weight where possible.
control arms F&R, trailing arms, subframe pieces, etc
You don't understand do you. The boomba tb will be the last tb you will ever need. You can use the same exact one on an evo. It doesn't leak. And it was by far the best purchase I have made for my car next to dsmlink.
Or if you want something bigger than stock get an evo tb and evo tps. However it will still leak.
the rubber around the door. mine is kind of faded and would love to replace that with fresh black ones without using a "universal" piece that not only will not work, but does not work
FP race mani heat shield with an O2 sensor bracket.. I know nothing of fabrication nor do I have the tools to make one myself.
Performance upgrade kits like: fuel system upgrade kit(fuel pump,injectors,and a fpr all in a kit for an affordable price) engine kit (oversized pistons, rods, all gaskets and hardware,full valvetrain and cams also all in an affordable price) turbo kit (turbo,headers,fmic and all IC piping couplers and clamps again in a kit. Like you go through pick what size and brand and get it all at once while getting a discount for buying all at once :)
All of this stuff is an afforable price allready. You can also get all of this stuff for a cheap price if you dont care about using shitty products.
I would like to see some more suspension options. TBQH some of the suspension stuff you could or still can get for Saturns is awesome and it seems like little to nothing is made for us.
Affordable when compared to what other type of car? Most of the stuff you mentioned is available, and mostly from our Supporting Vendors. If you look around at other cars similar to ours, you'll find that parts for DSMs are actually not too bad in terms of price. Turbo kits aren't widely available due to the fact that DSMers are cheap and only want to buy parts of what vendors would supply in a kit. They'd rather source all the pieces from the cheapest places separately. I've seen engine build kits and fuel upgrade kits available from our Supporting Vendors in the past for really good prices.
