Products the DSM crowd would like to see made
I would like to see more of a variety of timing covers, maybe chrome with slashes on the top with very fine mesh to protect the timing belt but to also make it look cool. If anybody understands what im trying to say. :coy::)
As far as i know there is no aftermarket DSM MAF.
There's no need. The GM MAF works with the translator and the Evo or 3G MAF can also work with just a little wiring. Both will read substantial airflow and are fairly unrestrictive, at least compared to the stock MAF.
If you surpass those, it's time to consider running a standalone with speed density tuning capabilities.
You want something like mine ? :thumb:
Ecmlink just released speed density. Evo/3g maf flows about 30% more than a 2g maf. It's not easy to outflow those, (currently I'm outflowing my 2g maf and would be close to a evo maf) but like he said gm maf will support anything you throw at it. I don't think anyone has reached the limits of it yet.
Yea but with slashes in the top with possibly a mesh screen so you can still see the belt....
Looks very nice..:thumb:
A newly designed heatshield for the FP manifold.
I have to agree with this completely! The only heatshield that is currently out is the JM Fab heatshield, which while looking very good is the biggest PITA to install! How about making the bracket bolt together, and then have the heatshield bolt onto the bracket with a seperate mount.
How about bottom Varis carbon fiber molding covers like they have for the evo's. that little carbon fiber piece on the bottom back of the evo bottom molding. I'm NOT talking about the carbon fiber diffusers!
Dude, they already have that. Go check the vendor announcement page.
I would like to see a company out there make a replacement door panel such as these. A thin sheet metal or aluminum that's a simple bolt on or pop on.
These are pics from a dsmtuners member on here and his 1G.
As far as cam covers go, check this one out...mine looks great!
Zaklee Corp - Performance Parts for Performance Cars
things that I would like to see in the near future for 2g's:
15 x 8 Rota Slipstreams (or any other brand wheel) in a +35 to +40 offset, 5 x 114.3 bolt pattern, 67.1 bore size (or larger borecentric) that someone on planet earth actually has. Rota lists it as a wheel that they make, but impossible to find and / or order 2 (instead of 24 for min order in Phillipines).
OEM style front bumper with built-in support for no crash beam, but minus plastic mini-blind cover that blocks the top portion of a good fmic.
aftermarket projectors that actually fit an HID kit (& ram air would be nice - now I'm dreaming)
cheap insert (pref cf) for rear bumper around tail pipe - tired of cleaning black crud off all of the time.
cf front wiper cowl
switch / led panel (located under aftermarket radio - covering pocket). It would be nice to have a place to put led's and / or switches like: meth level warning, alarm valet, angel eyes (halos), nitrous, etc.
interior light bulb kit - so you can change the color of all the interior lights (including dash) with just one kit (instead of wasting days trying to find every bulb individually).
a bracket for the brake fluid reservoir that does not corrode.
cf fuse cover (under the hood) with clear & white sticker for fuse locations
Iphone interface for dsm link v3
set of matching rear seat for aftermarket front seats
SS or aluminum door sills
some kind of wedge for the 3rd brake light to keep it from ratteling every time you hit a bump or turn up the volume on your stereo.
Not to be rude but can we e-mail this list to vendors?? Just so they know. JM Fab I'm thinking of right away. They'd make a killing off of us!! :D
I want to add my vote for a carbon fiber piece to replace the sunroof
That's why you get creative and mod the heat shield. I modded my brackets to stay on the exhaust housing and the heat shield bolts to it. Simple!
Evo X divided manifold with DSM head flange.
Evo X O2 Housing to DSM downpipe or V-Band.
Basically, a turnkey solution to mounting the very nice twin scroll EVO X 16G turbo in our cars.
I would pay for this. Essentially, it would be a very nice upgrade to the even ported 2G manifold and ported 2G or EVO O2 housing, and would allow you to run a very nasty, quick spooling turbo with proper internally gated boost control.
Ok me and a couple of buddies with 2g DSM's want these, now which vender is gonna step up and start making them I'm sure more than 15 people are gonna want these. We want a sunroof cf plug and will do a group buy, this item will be unique and am sure people will want it. :sneaky: Please Vendors step up and make this for us.
How bout some more 420a turbo parts that dont cost 3 as much as the same part for a 4g63. Im tired of fabbing up custom parts.
And i have a CF wiper cowl :p
There is one. It's like $400 and been talked about since early 08
ECMTuning User Support Forums
only thing i want made for dsms, are something so our turning circle will be less than a semi truck...
Window weather stripping (under door windows), always seems to peel on 1G's, only place I could find was MACH V but they were NLA. Would be nice to get some new ones!!
