DSMPT
DSM Wiseman
- 3,426
- 3,264
- Jun 12, 2014
Japan / Mexico,
Arizona
It depends on the oil and your setup/usage of the car.Whats the safe zone for a turbo 4g63?
Its not just 4G63 but any oil in any car. Oil has a temp limit and you dont want to go over that limit as it will breakdown and not be good as its job. Oil structure and quality plays a role and its why good oil is needed to stop this from happened normally. So what ever oil you are using read the data sheet (as all oil have one) and know the limits of that oil and grade. Knowing this gives you key advice of what to do, the interwebs will guide you but the data sheet with tell you exactly what you need to do and where to head towards and you can build to suit.Whats the safe zone for a turbo 4g63?
Great advice and will look into the valvoline vr1 data sheet. Currently im not monitoring oil temp. My next steps for the car was ecm link and some gauges. Car has been sitting for 12 years and just put the first 1k miles on it after the rebuild.Its not just 4G63 but any oil in any car. Oil has a temp limit and you dont want to go over that limit as it will breakdown and not be good as its job. Oil structure and quality plays a role and its why good oil is needed to stop this from happened normally. So what ever oil you are using read the data sheet (as all oil have one) and know the limits of that oil and grade. Knowing this gives you key advice of what to do, the interwebs will guide you but the data sheet with tell you exactly what you need to do and where to head towards and you can build to suit.
Also are you logging oil temps now on your car?
The oil data sheets won't tell you what temperature is ideal or even tell you an ideal range for oil temps.Great advice and will look into the valvoline vr1 data sheet. Currently im not monitoring oil temp. My next steps for the car was ecm link and some gauges. Car has been sitting for 12 years and just put the first 1k miles on it after the rebuild.
