Oil cooler
dsmBear
387
10
Aug 27, 2012
Carmichael, California
So it appears that the oil filter housing on my car, (engine is out for rebuild) had a swapped oil filter housing, and had 2 lines plugged with bolts for the oil cooler lines, but my car did not have an oil cooler on it... was this causing damage? Should there even be an oil cooler? It's a 94 with a 6 bolt swap
Oil coolers are generally recommended but not required, especially for a daily driver. It is most likely fine.
