- Thread starter
- #151
turboglenn
- 6,375
- 124
- Nov 5, 2007
RIpley,
West Virginia
425-450 is reasonable.
Stop crying at least its an option for you. I have to drive almost 300 miles to get to the nearest E85 pump.
That would truely suck to live that far from E85 (especially once use to running it)
Black Bullet said:This my friend is the bad part.
The higher i raise my boost the more annoyed I am with the cars performance on a lower boost...
I wish i wouldve never got used to running 23-24 lbs because 20lbs is so pointless to me that im not entertained at all. I dropped my car off at the paint shop for its paint job today and I always turn the boost wayyyy down and unplug my electric cutout anytime im away from my car ( dont trust people) and i went full throttle at 10lbs and almost fell asleep on the way there...
I guess because the goal is to never go slower...
I feel ya big time on that one..... Im so use to 23-24psi that i dont' know what's going to happen once i get use to 28psi on a daily basis
I've only had the car to 28+psi a couple times before in it's life. I've never run that much at the strip because before i couldn't get traction past 19psi, so everything i run this year will be uncharted territory for my car..... I can't wait till may 23rd this year because i'm going to go down to KCIR and make my first ever passes at 24+psi (hoping to be able to pull out 28-30psi by then)I need to get slicks first of all and then i'm hoping for some 1150's or bigger, but still haven't figured out what the minimum fuel system i can get by with to support them. Either way i'm sure hoping that this year on 24psi or more that i can break my previous best of 12.08 @ 117MPG on 19psi and get soemwhere in the 11's with a MPH of 120 or greater... Well, in one month i will have the answer, wish me luck!!!!!!! E85 eill be my "race fuel" I won't spend any money on leaded gas this year, if i can't do it on E85 it won't get done is the way i'm looking at it.
