ECMlink Flex fuel sensor configuration
Kenny4G63
Sep 10, 2020
Cincinnati, Ohio
I have searched high and low for this and not sure if anyone else has had this problem. First off I have a 90 Talon running SD. I have recently installed a E85 content sensor and ecm links wiring for the sensor. According to ecm link I should be able to enable sensor under the AuxMaps tab. Am I missing something? I belive it's something I'm overlooking. Here is the link http://www.ecmtuning.com/wiki/ethanolsupport
This is all you need to do if it is wired in correctly.
Thanks for the reply, this is an example. My screen here only has the secondary maps and secondary fuel adjustments columns. I'm 100% certain it's wired correctly per ecm links instructions.
  • Wanted 95 eprom
    Looking for 95 eorom
    • GhostTypeP0300
    • klipschaudio
    2g pass front rocker corner
    • dsmmario
