bastarddsm
- 5,781
- 1,719
- Aug 26, 2003
Mendota,
Illinois
First off, anyone who suggests I just get dsmlink will be slapped. Second, anyone who has not done any DSM eprom ecu programming work, that suggests this will not work, will be shot, with an elephant gun.
Onto my Idea.
The Federal DSM ecu has an input left open for the egr sensor used on the CA models. I want to use this as an input for a Flex Fuel Sensor. I belive this is totally possible. the FFS outputs a Sqaurewave with a frequency dependant on the %of ethanol in the fuel. This frequency could easily be converted into a voltage for the egr input to read. More information can be found here Flex Fuel with MegaSquirt
The tricky part is coding in the ECU, I know shit about machine language that the DSM procesor uses. But I think it should be fairly easy to tie the egr value into the global A/F ratio, and timing, on a global level.. I have two thoughts on how to do the fueling...
1. Two fuel maps, one turned for Ethanol straight, and one for 93 Straight. then the ecu computes a weighted average of the two A/F ratios from the maps based on the Ethanon content, and uses that number.
2. One fuel map, tuned for E85, and then the ethanol % is tied into the global injector compensation, to correct for gasoline.
I am not sure what to do with timing..My only thought was to have the timing map tuned for E85, and then have it globally pull timing based on the Ethanol content.
Anyone with experience have anyideas?
Onto my Idea.
