ECMlink Flex Fuel Question
Charliethatguy
5+ Year Contributor
47
13
Apr 14, 2018
Madison, Wisconsin
Ok so I'm thinking about installing a flex fuel setup on my 1992 Eagle Talon TSI. I have done some research and people seem torn as to where to mount the sensor. Some say to mount it before the fuel rail others (ECMwiki) say to mount it after the rail and before the fuel pressure regulator. What setup have you guys used? I'm also confused on how its supposed to be wired into the ECU. Do I have to pin it into the ECU or is there a connector I can Adapt to work coming off the harness? Any help is appreciated!
+2
I think the ecmlink site is pretty clear on how to wire it. It needs (I think) a 5v power, ground and the signal wire goes into one of the maf wires on the harness.
It is on the harness but honestly I haven't tracked it down. My setup was PNP at the MAF plug tho.
As everyone said, it better be next to the regulator on the return line.
The sensor has 3 pins, GND, 12V, signal. Signal needs to be connected to the MAF signal input of the ECU.
Thanks guys, I will re-read the ECM doc and mount it after the regulator. Thanks for all the input. If you have any tips on anything else let me know!
  • Wanted 95 eprom
    Looking for 95 eorom
    • GhostTypeP0300
    • klipschaudio
    2g pass front rocker corner
    • dsmmario
