miguelmcv
Supporting Member
- 2,718
- 261
- May 3, 2009
Fresno,
California
Our DSM pump produces 2000 psi, But the relieve valve will open at 1500 psi, so the rack only sees 1500psi, That pump will be enough to work with our rack.
Edit.
Steering pressure is from 1,209 to 1,309 psi.
With 1,500 psi, I don't think the pressure needs to be regulated.
Edit.
] I had his installed and running it has a lot of assist more so then the stock power rack and it works even when the engine is off, so if your car breaks down you can still steer the car as if it's running [assuming the battery still has charge], It really is a good setup, I know we likely will have more options as time goes on, but this is what I used with awesome results for the money.
