Please Support JNZ Tuning
mitsubishikid's Talon TSi AWD
Ownership Status
Currently Own
Eagle Talon TSi AWD
Turbo Type
14b
Drivetrain
AWD
Build Type
  1. Drag Race
190 lph fuel pump, custom spark plug cover,14b turbo with an turbo lines, hood strut conversion.
Mods-Engine
basic stock motor for now. upgraded larger oil cooler with 8 AN pro classic lines.
Mods-EMS & Logging
oil temp gauge, water temp gauge, boost gauge, dsmlink full version 3
Mods-Drivetrain
fidanza short throw shifter, 2 piece custom made drive shaft, torque solution solid carrier bearing bushings, skate board shifter bushing mod, custom made shifter base bushings, stainless clutch line, 4 bolt rear end swap, "05-"06 Outlander front big brake upgrade.
gab strut tower braces, rear decla rotors drilled and slotted, energy suspension urethane sub frame mounts, ST suspension rear stabilizer bar with urethane mounts. Volk racing: active rear toe eliminator, Volk racing: tubular crossmember, Volk racing: rear lower adjustable control arms, 3SX red brake line kit designed for a 92 fwd 3000GT SL, power steering pump and lines deleted, de-powered rack lines plugged with brass plugs, custom electric assisted steering setup.AGX adjustable damping struts front and rear.
Parts Wishlist
real mhi big evo 3 16g.
evo injectors.
speed density
1gb engine wire harness.
carbon fiber roof
carbon fiber hatch
carbon fiber hood
Background
I basically saved this car from the crusher, I learned a lot from the car and did a lot of work on the car, I plan to over time build it into a drag car possibly or street/track car.
  • Like
Reactions: Ludachris
mitsubishikid
More in 1G DSM
More from mitsubishikid
Share this Vehicle
