- Thread starter
- #76
turbosax2
Moderator
- 4,483
- 674
- Nov 19, 2006
Mechanicsburg,
Pennsylvania
Tons of gaskets, seals, timing belt stuff, bse stuff, wiper cowl stuff, coolant reservoir, brake reservoir/cap, clutch reservoir/cap, power steering cap, fuel filter, upper heat shield, oil cap, radiator cap, thermostat, valve cover gaskets, dipstick, new grounding straps, radiator hoses, coolant hoses, random clips and some interior parts, intermediate shaft spacer, and a shitload of bolts/washers/nuts. I'm a self proclaimed hardware whore so nearly every bolt/nut/washer is getting replaced in the engine bay and front suspension. The "important" bolts were bought oem and the rest will be replaced with stainless steel hardware. All in all, my parts list comprises of about 150 different part numbers.
) i need a new one
My hookup with a blast cabinet keeps backing out on me so the blasting has been pushed back weeks, but I hope to blast some things on Tuesday. I also need to get some things welded, but my hookup on that has been busy so I'm waiting patiently.
. At first I only let it sit a few seconds before scrubbing, but I soon learned to let it sit for at least 10 minutes so it can work it's magic. After a few applications most of the tar is gone - only a few little spots remain that I can pick off with my fingernails. I was very pleased to see that the putty knife left very few scratches on the body. I'm going to give in and pick up a few cans of compressed air tomorrow to hopefully make the firewall and wheel wells easier. I also taped up some more unused connectors - all the connectors for the hvac stuff I removed, the little light that lights up the cigarette lighter (the yellowish tint won't mesh with my custom white led interior that I have planned), the light that goes in the cup holder (c'mon, it doesn't even light the cup holder up well and that's one more thing I have to remove to get the center console out), and I taped up the amp connector and stuffed it under a brace running across the floor. I kinda have the urge to remove all the unnecessary wiring in the interior now, but I just don't have time for that at the moment. I go back to school in 2 weeks so after that I'll only be able to work on weekends. Pictures of the interior will be posted after I finish gutting it all and clean the whole thing with a Simple Green solution. I would love to paint the interior now too....
The carpet looks like a lighter shade of gray than mine - is it dyed/painted? Great job though, hopefully mine will look 1/2 as good as that!
