- Thread starter
- #51
99gst_racer
Moderator
- 12,010
- 1,706
- Apr 5, 2003
Coloma,
Michigan
Great question. Originally, the plan was to use two intercoolers. I was going to squeeze a big sidemount in there for cooling between stages. But I soon learned that to be efficient, I would need to use another cooler the size of the FMIC that I already have - and there's just not enough room for that. Then, I considered spraying methanol between stages. Well, with a GM MAS and atmospheric dumped BOVs, that's just not feasible. So, I landed on direct-port methanol injection.What are you planning to do for cooling? E-85, meth? I would think that the air would be twice as hot since it's going through two compressors. Correct me if I'm wrong.
It's going to be a bit before I build the kit though. I'll be running it on 110 octane fuel for the first month or so. I'm hoping to eventually use meth injection and pump gas and run 35+ psi. I'll probably install the meth set-up when I send the compound set-up off to be jet-hot coated. It just has to fully prove itself before I drop the coin for the coating - and a large part of that means going to the dyno.
But, even still, each turbo is going to be running in the middle of it's best efficiency island. Each turbo is gated at only 11.5psi so they're not working up much of a sweat. I'm willing to bet that the air charge won't be much warmer at all, if any. But that also doesn't mean that there isn't room for improvement on the air charge temperature.
. Seriously.
