My 600HP DD build by me and the Co-Workers at Strictly Import Motorsports
TofastForU_99
781
10
Mar 1, 2009
Kalamazoo, Michigan
The project-------- 97 Eclipse GSX
A huge thanks to Strictly Import Motorsports (www.StrictlyImportMotorsports.com and Jeff for the Powder coating at Jeffs Powder Coating
Goals 600HP/11 sec 1/4 mile at least.......
The plan
ENGINE:
BUILT by me and Strictly Import Motorsports
6 bolt block
Balance shaft Eliminator kit
Bored .020
Decked
EVO 9 .20 over pistons
6 bolt rods
ARP main/rod/head bolts
HEAD:
6 Bolt head
Ported Polished and Knifed by Strictly Import Motorsports
Super tech springs/retainers
Viton valve seals
back cut stock Valves
SIM 275 CAMS
Drivetrain:
Stage two SHEP Transmission
Fidanza Light weight flywheel
ARP Flywheel/Clutch bolts
ACT 2600 clutch
Exedy EQUAL slave cylinder
SHEP transfer case
LSD rear
SIM Raceline Racing Axles
TURBO/FUEL:
Holset HX35
BEP housing
FP RACE Manifold
Extreme PSI oil feed and return line kit
Aremotive A1000 AFPR
FIC 1000cc Injectors
Walbro 255 Fuel pump
Tial 38mm Wastgate
HKS SSQV3 BOV
Punishment O2 housing recirculated back into 3" exhaust
ETS FMIC with 3 inch ICP
Engine Management:
DSM LINK V3
AEM Tru Boost
AEM UGEO
Suspension/brakes:
Eibach sportline springs
KYB GTR II shock/struts
Prothan Motor mounts
Prothan front and rear bushing kit
Big brake kit
Drilled and slotted rotors
Hawk pads
MISC:
COP Setup
Tuned to E85 for daily use, race gas on the drag
All Felpro Gaskets
Roll cage
Battery Relocated to trunk
ALT Relocation
Gates racing timing belt
Gates Racing ALT Belt
Gates racing Radiator hoses
Alum Radiator
EGT block off
Alum spark Plug Cover
Cosmetics:
Rear wing eliminated
VIS stock CF hood
black 18 inch rims and tires
CF front lip kit
8000k HID's
Black window tint
tail light black out
new license plate :)
I will be Posting Pictures very soon and will be updating project on a normal basis. currently are in the process of removing the 6 bolt out of the car to put in the almost finished built 6 bolt. I'm looking to have the car finished by the end of february and will be running the car at the 18th Annual DSM/EVO Shootout At Buschur racing also plan on putting the car on the Dyno. Wish me luck and any input will be helpful.
sounds like it s going to be an awesome build!!! i would go with an hx40 if u want to get close to 600hp and a set of forged rods so u dont have any worries about one letting loose! just a suggestion
yah I have been thinking about getting a HX40 with a Pro wheel and the t3 housing with a t3 manifold. and a 44mm tial, I guess if someone bought my BEP housing and HX35 and 38mm tial for what i got it for i would change the setup but thats the least of my worries I will be testing this car all spring so i will have plenty of time before the shootout Dyno run to swap to a hx40 PRO. I also took Pauls suggestion and called street and strip and got a great price and Idea on what kind of cage to get thanks Paul.
Todays progress
Stripped the head, Hot tanked it, finished the Rods and got a few goodies in the mail. here are some pics.
Here are my rods before and after Strictly Import Motorsports got a hold of them :thumb:
Just tossing out another reference for a cage builder, Jamieson Fabrications. They are right off of M43 when you are coming from Plainwell to Richland.
Owner's name is Andrew, and his shop does an awesome job. He's certified to do NHRA, IHRA, and SCCA. They do a lot of custom tube chassis cars for some high end customers. Just had dinner with him last night, lots of cool projects go through his doors.
Jamieson Fabrication Unlimited
thanks for the refrence i will be sure to give him a call. Also another quick question what does my cage have to be rated for. im new to the cage stuff and i dont even know where to begin. I have talked to a few people and got a few Ideas. Im leaning to a 10Pt cage just need to figure out what i need to get it certified as. I plan on running at Martin a lot and the shoot out.
Well there was little progress made this weekend on the build. I basically got everything stripped out of the GSX and ready for the roll cage to go in here in the next week or two. sry these pic dont show a lot.
If you don't plan to run any quicker than 10.00, then just stick with an 8-point similar to the one in my 1G. PIC1 PIC2
I'd also recommend chromoly tubing over mild steel due to the great difference in weight.
I doubt ill run anything even close to a 10.0. I was jsut unsure of the requirements at the track. But yes I paln on doing a chromly cage and will probably end up going with a 8pt. thanks for the help 99gst racer.
Just ordered my punishment racing O2 housing. Also I am not sure if I should get tokico HP shocks and struts or KYB GR-II's any idea's?
Just ordered my 8 pt chromoly roll cage from BD racing. should be here next week. :) Also if any one has any rear lsd axle cups and LSD rear end LMK thanks.
Yes, this IS a nice build. You should put it in a blog where you can organize it more. It will really help everyone when referencing and also having more concise access to details needed for others when researching.
You should be looking at the stock housing 7blade hx35 for 600whp, but the bolton 8blade can do 11s all day long. So you really have 2 separate goals there. . . The bolton hx40 will give you that 600whp number too. And put you in the 10s as proven. But if you're going t3 (good for uprading later a t3 hx40 is a 700whp turbo), I'd look at the 7blade hx35 with the stock hx35 housing and an open (non-divided) manifold. WAY MORE than enough for your 11second goal and probably a little easier to find than the hx40 pro.
Ya he has yet to update this yet but his hx35 set up is for sale and he is in the market for a hx40...
here are some goodies I got week and the progress that we made this weekend.
How do you turn this into a blog?
this week i will finish polishing the head and i will hopefully finish my short block.
Also I am sending all my parts and intercooler pipes and brackets and what not to jeff powder-coating to get my parts powder-coated and ceramic coated.
we managed to pull the motor in 3 hrs with no power tools and a 24 pack of bud light :)
well progress has slowed down hte past week i have been super busy with school. progress that has been made is I switched my piston setup from .20 over 2g NPR to .20 Evo 9 pistons. I just bought a LSD rear end and I bought a VIS stock Carbon fiber hood and a new set of 18 inch rims and new tires, and a 8000k HID kit, I also sent out all my parts to get powder coated cant wait to see them :) . unfortunately I will not be working on the car this weekend but will e installing the roll cage the next weekend. I will post pics of the roll cage instal and my new rims and tires and CF hood and my lsd rear end swap. unfortunately I still need some LSD axle cups so if anyone has any let me know thanks
recently just got my delta regrind 274 racing cams in and let me tell you these things are sweet :) ill post pics tonight. I also just got my HKS SSQV BOV in the mail i went with the limited edition black to match my color scheme. Also I will be posting pics of the CAGE intsal thise weekend cant wait. Also will be installing my CF VIS hood and my new 18's LOL. I also have to start on my rear LSD swap and probably remove all the suspension for my new shocks and struts (still undecided on TOKICKO ILLUMINAS or the KYB AGX). cant wait till this thing is finished pics coming :)
okay here are some pics of the cams and BOV.
Well a lot of progress was made this weekend. I got the car to its new home for the next couple of weeks for the cage instal. I also got started on the full interior wire tuck. I put my new rims and tires on but they are coming off to get powder-coated. I pre fit the cage and everything was pretty much perfect. I am planing on working on it this coming up saturday and finish up the roll cage and rear end swap along with my new shocks struts and brake setup. Then hopefully be putting the motor in in the next 2 weeks.
So here is the progress that was made today :) almost done with the cage I got the CF hood put on and mounted up looks great :) also messed around with the rims cant wait to see them when there tied in with the car. LMK what you think. motor will be going in this next weekend and roll cage will be getting finished along with racing seats put in.
yah cant wait kinda going after a Ken Block look white rims with yellow spoke but im doing black and pink and im doing a DC logo in it or MITSU undecided LOL.
