knochgoon24
DSM Wiseman
- 6,135
- 98
- Jan 29, 2008
Troy,
Michigan
Does it really need to be adjustable? It seems like there are only 2 heights.
Their Pro/E model was imported from something else, so there is no parametric data associated with it; it's just "dumb" geometry. Not sure I can use it to generate a swept (curved) beam.
Could you even bend it? Aged aluminum does not like to be bent. I pretty sure it has to be annealed and then reheat treated. Heat treating something like that would run what? Around 250 or so.
I'm willing to bet that it would be really hard to work with. Getting good solid welds or even a smooth bend looks like it would be difficult at best.
I agree they should just make two different ones. I'd also bet 90% of them would be ordered for a cut front clip.
So far none of the fixed designs have even met the two height requirement. If we can meet that, I'll be happy. Any other adjustment is just icing on my cake (or pie).
And yes, I know I'm stubborn and picky.
So then you have a pulling and twisting motion against the frame rail mounts.
You have that already, as all of the FEA plots have shown. The trick is coming up with materials and dimensions that minimize it and still meet the design criteria...which is what we are trying to do.
Eric, would it be that big a deal to notch the mustache, so the hook comes out in the same location? It looks like the notch would be virtually invisible even if you didn't have the hook bolted in, since it would only be the thickness of the hook and it's recessed and up at the top.
Keep in mind, ALL 2g bumpers sit at the same height. While notching the mustache on a 2gb may not be a big deal to some, I sure as heck wouldn't want to make a notch in a 2ga bumper just so I didn't have to design the part to sit at the proper height.
Ummm... ok. What does that get us? Didn't you need the second position to be lower and not higher?
I'm headed out of work and about to have some drive time. Call my cell if you want.
Do you guys know what the OEM bumper weight is? I didn't see that posted anywhere.
What you modeled puts it at the yellow. Flip it upside down and you get the red.
The mustache is part of the bumper cover.
No, I haven't decided on the tow hook. I'm open for discussion on that.
