Stapl3
DSM Wiseman
- 2,345
- 1,074
- Oct 27, 2004
MI,
Michigan
Nice!! The log looks fantastic for moving forward.Alright! At op temp. Timing gun set to zero. Pin is Grounded. Car is Idling between 800-900 RPM. Showing 5* before TDC.
Air flow per rev is about .15 right now. If target is .25 then I should back out BISS a hair? Just going opposite of what I believe was mentioned above.
Here is a warm and fresh Idle log.
Edit: I only have a bicycle pump. Not really feeling the urge to put my efforts into hand pumping the system to 25+ PSI,. So I may run her down to a local shop and datalog on the way. Just have them do the boost and vacuum test done along with the compression test to bring those numbers up to date.
I use airflowperrev barely as a sanity check, I've never chased a value there. You should do a WOT pull to at least 5500rpm to calibrate the fuel system, then we can smooth out the SD table. There's no reason to bother with SD airflow adjustments when the fuel system isn't calibrated. And a large component of airflowperrev is the airflow adjustments.
I know the process seems like it should be get idle right, then cruise, then WOT. But it's actually kinda the opposite of that.
