- Thread starter
- #26
jmt2028
- 57
- 57
- Apr 13, 2022
Memphis,
Tennessee
Im at 42.6 and -300. But it feels like a slight studder now from when I step on the gas and see the response on the rpm
That will improve with VE and timing adjustments. Right now, you need fuel calibration in the ballpark so you can start tuning.Im at 42.6 and -300. But it feels like a slight studder now from when I step on the gas and see the response on the rpm
Whenever I go to do a pull, if I see knock, what is the best course of action to correct the knock?The pull you want is 3rd gear from 2000rpm up to redline. If you start to get knock, or see the AFR on the WB above 12 - back out of it. - Run your lowest boost
It depends on other factors. Knock is an indicator. You may have too much timing, boost or compression for the load factor. Reducing boost is the normal approach. The ECU will reduce timing to save itself because its the fastest way to prevent detonation.Whenever I go to do a pull, if I see knock, what is the best course of action to correct the knock?
Looking at an average of the Combined FT values on your cruise, it looks like global deadtime or cruising VE could be adjusted. The Combined FT average is about 4.2% off.Understood. Here is my log from when I was driving home. It is a bit lengthy as it is a 30 minute drive. 12.08-08 is idleing right before I started to drive after I made your suggested global fuel and dead time adjustments. 12.08-09 and 12.08-10 are the cruising logs.
