Evo VIII Cams in DSM? [Merged 5-9] 8 cam
acidxrain
32
Oct 20, 2002
My friend is upgrading the cams on his evo VIII so he'll be getting rid of the stockers. Would the stock evo cams be a good upgrade for my car (97 gsx)?
The cams are not the only thing that has been moded and made to work from the evo to the dsm.
Kiggly made the evo 9 intake cam gear work. (the mivec one)
I read the threads posted and so far no one has posted good information. It doesnt sound like anyone has a clue really to why they are different. To me it sounds like guys are lying saying they did it just to win argument that it can be done. I had customer buy some evo cams for DSM. I played with the cams on the bench swapping back and forth trying to figure out the quick and easy way to do this. I too reasoned this would be easy till I actually tried to do it. There are two problems. First one is cam drive is rotated 90 which is easy fix so i wont discuss that problem. The real problem is the pin for cam gear is in wrong spot. And its not just easy fix by installing gear 11 or 12 tooth off. Heres why. The engines are mirror images of each other. IF VALVES WERE INSTALLED AT RIGHT ANGLE TO HEAD SWAPPING WOULD BE EASY. The problem is the valves are installed in head at angle. I havent measured this angle but this angle is the key to getting this swap right. Lets say the angle is 10degress. The mirror image of that 10degrees is -10degress. So gear would have to be rotated 20 degrees. Now seeing as each tooth on cam gear moves cam 7.5 degrees. The nearest swap would be 3 teeth. That would move the gear 3(7.5)=22.5 not exactly ideal if valve angle is indeed 10 degrees. Whats needed here is the knowledge of what the true valve angle is. then one could calculate how much a stock gear needs to be moved and how much degree an after market gear needs to be set at to compensate. The actual perfect valve angle would be half that 22.5 degress at 11.25. Or half of two teeth at 7.5. So if valve angle in head happens to be 7.5 or 11.25 then this swap would be easy. other wise this swap gets complicated real quick.
Most of all vehicles sold in the US run clockwise!
Bunch of idiots, who are so quick to tell you what cannot be done on this forum. I am so sick of reading all these so-called experts with no information.
Here is a 2.4L with an Evo 8 head:
YouTube - nastiest galant ever...UNTUNED first startup
See the motor spins towards the front of the car? Ever once pay attention to your own car? The motor spins towards the back of the car.
So here is some KidsPix style images for those with no imagination:
So there you have it, no amount of arguments will amount to anything that makes that incorrect.
Since Evo's constantly use 4G64 from 2G DSMs, that means that the bores have to be equally spaced and the decks of the blocks symmetrical in order to work. Which means the spaces between valves must be equal even in reverse to line up with the bores properly, and since each set of lobes is set 90* difference from the next set, that means the camshafts have to be identical, minus the notches and cam gear noses.
Which means notch the intake cam and mark your new timing marks and bam they work.
Yes the engines spin in the same direction, this is well known, and it also leads to the logic that this swap is indeed possible.
You may have neglected however, that both DSM and Evo 4+ have the exhaust cam towards the front of the car, which means the cams are not acting on the rockers in the same manner if you change which one goes in which side of the head. Valve timing is the problem to be solved.
This is what 94awdcoupe was referring to in post 180. The rockers do not sit exactly in line with the cams and deck, they sit in line with the cams and valves. The difference in angle between valve stem and deck on a DSM head versus the different (and reversed direction) angle on the Evo for the same cam means a different portion of the cam lobe will be in contact with the rocker when the timing is set the same.
The way to make this work is simple enough, use a degree wheel and dial indicator to degree each cam first on the Evo engine and then swap them into a DSM and degree the cams so they match the Evo specs, then just remark the cam gears for the new correct timing marks. I'm truly surprised nobody has posted a video of an engine running this cam swap yet. The machining is fairly simple.
Incorrect, same side of the lobe makes contact with the rocker, grab a camshaft mark a lobe with something, spin it clockwise both in Evo orientation and then flip it like you needed to put it in a DSM and spin it, you will see the lobe side that touches the rocker to open the valve and then the lobe side as it closes the valve is the same.
The mistake people keep making is they don't understand what mirrored means.
You misunderstood my post.
I agree with your reply though.
The point I was trying to make is not about the side of the lobe that makes contact, but where the timing marks are when the cam is correctly timed. Visual aid forthcoming... bear with me please.
In the drawing on the left a cam is installed and the valve is on it's way back to closed position. Now the same cam is timed the same but placed in the other head, with different valve and rocker geometry. Now the valve is still opening with the cam timed the same. That's why lift and angle need to be corrected by degreeing the cam if it is swapped. That's all I was saying.
Of course I assume you're using the exhaust cam as an exhaust cam and intake cam as an intake cam on both heads.
need to set them up to use the 1g/2g cam sensor and make new timing marks and they will work. as long as you use the intake cam on the intake side and the exhaust cam on the exhaust side.
personally i dont think it is worth it unless you have the parts laying around and it will be no cost to you.
Any advice on how to resolve that if you don't have access to an Evo head?
All you really need are the cam specs as factory installed in the Evo.
Once you have the centerlines (or the crank angle for 0.050" open/close) on both cams, all you need is a degree wheel, dial indicator and a solid or static height HLA to measure and adjust valve movement directly.
I have put some evo cams in my 97 talon using the evo cam gears. I have not been able to confirm using the evo cam gears but it seems it is easier to use the evo cam gears over the dsm gears. The evo cam gears only have the timing marks on the inside of the gears when used on the evo head, but when installed on the dsm head it seems that all you would need to do to time it is put the cam marks on the outside instead of the inside. Has anyone else tried to use the evo cam gears when using the evo cams in a dsm?
It's not that simple. Take a look at this illustration I modified from the one above.
See how there's a difference in the positioning between the cam and rocker? That difference changes the valve timing. With the cams aligned in the Evo the valve will begin moving at a different angle of cam rotation. In the head on the left the cam will be closing the valve as it rotates further, on the right it will open further. Notice that turning the cam 180 degrees will position it like the second cam lobe in the right side of the drawing. This is still not the same valve timing as the cam on the left.
Doesn't anyone use a degree wheel these days?
I'm the guy that tried it. Actually, I did finish it but it's not worth the effort. I was 17 years old and everybody was telling me that it can't be done. To me that was just motivation to keep going with the little project. I did all the measuring and fitting in my bedroom by myself. The Evo 8 cams WILL fit into a DSM..but the gains to work required ratio just aren't worth the hassle. It's pretty much an "I told you so" mod. Go buy yourself a nice set of regrinds instead.
HA! That was probably the flatest-out, straight-up response I've heard in a long time! :thumb: Thanks for the honesty!
Oh and I drive through Hughesville once a week! :D
I no they fit in me being a dummy and wanting to no if they work i put them in and in time and the car seemed like it was starting up back words... There was exhaust coming outta the intake mani and was suckin threw the exhaust
