91 talon tsi. it was modified on the to look like a 1gb (fixed healights). stock rods and pistons. fmic, gm maf sensor, s90 throttle body, c.o.p system, blow off valve, tial open waste gate, adjustable cam gears, koni suspension, catch can, maybe a few other goodies, needs an exhaust. internally, balance shaft delete, stage 1 Brian crower cams and stiffer valve springs, stage 1 clutch cant remember the name. the body is rough over all. missing one or two plastic panels. paint sucks, frame is solid but has a rust spot on pass side rocker about a foot long, the paint is beginning to chip. interior is 7 or 8/10. dash is good. it needs an alternator, it runs and drives, but the alternator eats batteries. that said, the tires need balanced, but good tread, ive gone through all the gaskets on the engine, transfer case, and transmission. everything is leak free. stock inj, cpu, turbo. engine rebuilt 10k ago. price is firm. selling bc it needs tlc, i dont have time. transmission shifts great, no grinding, doesnt pop out of gear. located 20 min outside of frederick md 21702
I swapped out my ecmlink and 950 injectors, it will run fine without those but due to the gm maf needing some settings adjusted, along with the other mods, ecm link would be a good idea.
