2G Evo 9 oil filter housing
So what housing can I run on the 6 bolt I don’t want to run that big ass cooler on the stock one since I am not running coolant through it anyway???
The 1990 turbo housing?
A forward facing housing (Mighty Max)?
A 6-bolt non-turbo housing?
Removing the water cooler and cutting down the stud to mount the filter directly to the housing you have, see: 2g oil filter housing/water cooler delete??
Any of these would suit your purposes if you aren't running coolant to the water-cooled oil cooler.
edit: doh! too slow...
Do you want to run a cooler? If so, find a 1990 OFH.
