NWHTanK's Eclipse GST (AWD swap)
Ownership Status
Currently Own
Mitsubishi Eclipse GST
Drivetrain
FWD
Build Type
  1. Street
  2. Drag Race
  3. Autocross
  4. Showcar
Vis hood. Talon conversion. Carbonetics,doors,hatch,sunroof plug. ACW polycarbonate rear wind screen.
Mods-Engine
Non turbo 6 bolt block. FFWD 2.0 aluminum long rod rotating assembly. Billet steel main caps. Kiggly girdle. 3g lifters. Evo rocker arms H11head studs.stainless valves. Comp272 cams.bee hive springs. FP ball bearing black. Morrison fab exhuast manifold.Punishment racing externaly gated o2 housing. Moroso aluminum oil pan.FIC 2150 injectors.multi layer head gasket.intake heat barrier gasket. 7bolt Ported and polished head.Egr port welded shut on exhaust side.Jmf 7bolt intake. S90 throttlebody.Complete gasket and seal kit.Mitsu water pump ,6 bolt straight cut gears oil pump,and timing belt kit. Coil relocation bracket.NGK plugs and magnacore wires.90 poted filter housing. Air oil cooler. Fluid dampner.Fiav delete. Egr delete.Avid motor and trans mounts. JMF sheet metal intake . Galant alternator with relocation kit and kiggly pully. Evo Spec water pump pully. Scatter Shield. Mk4 radiator. 1g fmic intercooler. Tial waste gate and bov. FTY remote oil filter housing.Kiggly HLA.SS water pipe with heat delete.
Mods-EMS & Logging
Link v3.LC-1.SD. Innovate guages, Afr, boost with shift light, oil press and temp, coolant temp with volt . Dyna tech ignition box
Mods-Drivetrain
95 talonAwd swap. TMZ PPG,billet mid plate, 300m output shaft,evo 3 5th gear, evo mech front locker with wier plates, evo3 shift rails,magnus 1-2 shift fork. Tmz 300m tcase,Boostin perfomance mid case, magnus front case.TMZ rear diff, Frontline fab billet caps,TRE ninga side plate,evo 3 locker with wier plates, Frontline fab rear diff cover.Short thow shifter.Aluminum drive shaft. Aluminum subframe bushings.Poly rear diff bushings. Dss axles front and rear, Dss aluminum drive shaft. 6bolt competition clutch flywheel. Southbend single disc for the PPG input shaft. Tubular north south bar. Competition clutch fork.
Front and rear Rand M sway bars.Tce big brake kit, 13 inch rotors, 6piston wilwoods front 4piston rear.Rear tube subframe.17x9 wheels 255/35/17 tires. SS lines. DG Koni coilovers. Paul volk front and rear lower control arms. Fiba quik ratio non power rack and pinion. Fiba rear upper control arms. Vamous design front tube subrame. Fiba front subframe brace. Boosted fab front strut tower brace.DC rear strut tower brace. Porsche front brake air guides. Full A/C and heat delete (wieght reduction).
NWHTanK
More in 2G DSM
Share this Vehicle
