- Ownership Status
- Currently Own
- Year
- 1999
- Model/Trim
- Mitsubishi Eclipse GSX
- Drivetrain
- AWD
- Transmission Type
- Manual
- Build Type
- Street
- Mods-Bolt-on
- Hx35
Duel fuel pump hanger
8 feed 6 return
Treadstone Intercooler
- Mods-Engine
- Engine good to 700 awhp
6 bolt
JE 8.5:1 piston
Eagle rods
Mhi oil pump
Balance shaft delete
Acl bearings
Water pump
Timing components
Water pipe
Oil filter housing
Arp head studs
1g head with bc springs/retainers
Revised lifters
Rockers
New valve stem seals
Mitsu mls head gasket
Water neck
Valve cover
Oil pan
All new seals
engine cleaned inspected and assembled
- Mods-Drivetrain
- Shepherd stage 2
- Mods-Handling
- All new front suspension
Solid subframe Bushings
Evo brakes on the front
Abs delete kit
