IvanovBG
- 75
- 73
- Aug 9, 2024
Vratsa,
Europe
Hi guys,
I drive a 1993 Eclipse GS. It has a stock non turbo 7 bolt engine.
A few months ago, I noticed a weird noise coming from the engine bay, which I believe to be pinging/detonation, after reading this older thread: https://www.dsmtuners.com/threads/grinding-rattiling-noise-when-accelerating.435464/#post-152970553
I can hear it during normal driving conditions, but it gets worse when the engine is under load on steeper hills.
The noise is present only at lower RPM's, and it goes away after I go past 2000-2300RPM. It starts only when the car reaches operating temps, if the engine is cold I don't hear anything, even when lugging it in a higher gear.
The check engine light isn't on, but I don't have a tool like ECMLink to check any logs.
First thing I did was to buy a timing light and make sure the timing is correct by following these steps from VFAQ: http://www.vfaq.com/mods/wayback/BradBauer/engine/timing.html
Even with the correct factory timing, it still made the noise, so what I tried next is retarding it. The noise went away only when the CAS is almost completely turned clockwise to retard the timing as much as possible.
The car is drivable, but accelerates quite a bit slower, so I tried swapping some parts that I read could have helped.
New parts:
- Spark plugs (NGK BPR6ES)
- NGK Spark wires
- Coils
- 82°C Thermostat
The radiator is also new from a couple of years ago, as the neck for the upper coolant hose on the OEM one broke. I swapped the MAF as well, because I have a backup replacement, but it didn't make a difference.
The car is driven only with 95+ or 100 octane fuels, which are the highest grades possible in my country. I used Liqui Moly Injection Cleaner a couple of times to help with possible carbon buildup as well.
Any ideas what I could do to remedy this? If the knock sensor is bad, could swapping it help?
PS: I'm new here, so if you'd like to check out the car, this is my introduction thread: https://www.dsmtuners.com/threads/new-member-1993-eclipse-gs-fwd-naturally-aspirated.547297/
New parts:
- NGK Spark wires
- Coils
- 82°C Thermostat
