1G Eclipse 1g NT fuel problems
Lancer_lover
181
60
Apr 18, 2017
kristianstad, Europe
Hello again ive changed my fuel filter to a fuellab looking filter and AN 6 adapter to the fuel rail because the oem one had just and tiny hole going into the rail . and An 6 fitting from the rail to the filter and down to the fuel line . But now its acting wierd (DSM LIFE RIGHT) it acting like it has a bad fuel filter and u can her it if u rev it a little im gonna upload a video for u guys .
Thats just corrosion on the fuel pump, it wont stop your car from running. That sensor looks like the knock sensor wire.
Ok thank u :) now iknow :D
Ok so now ive changed the CAS sensor and still nothing and fuel pump works . This is how the spark plugs look like ? Before the last time i started it up and drove it . It had like no power ? Then this happend so ill change spark plugs and try again . It cant be the ECU ?
I took out the ecu and sent it to a company who is gonna test it and change parts and stuff so lets hope it start when it comes back :D
Im baack and a working car ehm kinda
First the fuel filter is bad and i wonder if its the right way mounted ? Yellow tape is downside . But im gonna find a new filter and se if the surge and hesitating is gone then .
Well kinda searching i took out the battery and recheck everything and it works now no hesitating at idle or revving it :D .. but if u put it in reverse or 1 gear it start revving high and dont stop and if u driving it it will keep on driving or atleast try LOL
Anyone ?
New day new problems looks like it bogs as hell when u drive and it sounds like it hesitates again with the new filter!
Took out the 4 spark plugs and the oxygen sensor and they look like this ? All white ? Tps looks good to​
looks lean...
stock filter?
looks lean...
stock filter?
Agreed.
Hard to tell in the plug pic since it's so far away, but the ground straps looks ghost white, and the base/ceramic have what looks like oil residue. O2 sensor looks to report lean as well.
I'm thinking filter, or maybe injectors are clogged. The yellow section of your fuel filter should go towards the tank, so down. If it fell apart it may have pushed crap into the injector baskets, causing a majority of your problems. Pull the injector and check them for crap on the feed side.
looks lean...
stock filter?
Yes everything is stock :)
Agreed.
Ok ill try that :)
I think i found it ? Those seals look bery old and one of the isnt even round
Replacing the seals is a good idea, but pull the injectors off the rail and see what the fuel inlet side of them looks like, make sure there's not a bunch of crap from that disintegrated filter in them.
thanks dude you guys killing it with help :D injector 3 had some gunk in it ill try to clean it with some engine starter fluid
Make sure to backflow it when cleaning, don't want to force anything through the injector body.
Might want to try using a 9v battery or something to pulse the injector pintle and let things loosen up to help clean it out.
What kind of injectors are those? They dont look like stock injectors at all. Non turbos use 240cc pink top injectors for 1gs . Did someone throw in some after market injectors for more fuel with out a way to tune ?
I used to be n/a and when I bought my car someone threw in the 390cc injectors and the regulator had nothing but problems with them!
( My car was turbo to non turbo swap in defense of previous owner ) even had the turbo ECU and resistor pack for the low impedance injectors but never ran right until I swapped them back to factory . Would stall ect..
They are definitely not stock n/a injectors and have no business in an n/a dsm get the pink tops unless you have a way to tell the ECU how to talk to them.
No they are the correct ones 275cc are standard on EUdsm :) so iknow they arent the problem because theu work very good before this happend
Ahhh kk didnt notice you had a euro dsm LOL sorry man although would of been cool if they were the issue LOL I was like wtf ! Do you have the correct euro ecu for it ?
Hi guys :D good news it is working again and even better that before :D
The seals on the bottom where old and the injectors where clogged up as a mother f××ker :D thanks guys for all the help :)
Glad to hear you got it sorted, thanks for posting back your solution! In "thread tools" at the top right of the thread you can change the title to "resolved" if you'd like, that way everyone knows the solution you came up with! :thumb:
I took out the fuel pump and i notice that the filter is very brown OMG and i dont know what those white spots are on the fuel pump
do anyone know what that is ?
The filter being brown is a direct result of rust that got in your tank. The white spots are more than likely the carbon scoring that got left behind after fuel being burned off. I say this because I'm restoring my Talon and mine cut off on me after sitting up for yrs. I emptied the gas tank, removed the tank and took out the fuel pump and fuel sender...same problem. Removed the fuel filter, looked like I had tea in there. My suggestion would be to clean your tank and get a new filter then give it a go with some fresh gas.
Hi everything works now it was rust in The injectprs that got stuck + bad seals but it all got replaced att it works amazing now :)
I'm glad to hear that. I took your idea and removed my fuel injectors too. Mine were rusted on the inside, the filters almost tore removing them. I got brand new filters and seals for all of them. BTW, nice Eclipse. Gotta get mine repainted and I'll post new profile pic after.
