daren_p
DSM Wiseman
- 4,604
- 98
- Nov 22, 2004
Newmarket,
ON, Canada
I'm about to swap out my valve springs, which I haven't done before. I have a valve spring compressor that will work with the head on the car (don't want to take the head off) but was looking for any ideas on how to keep the valves in place? I'm thinking to rig something up that allows me to pressurize the cylinder through the sprarkplug hole. If anyone has made such a thing or has done it another way, let me know. If you have any other pointers on changing valve springs, that would be great.
You might also want to make sure that piston is at TDC. That way just in case you drop a valve it won't fall into the cylinder. You can just use a magnet and pull it back up. And I can't see why you wouldn't buy the tool to pressurize the cylinder when you have the OHC valve compressor that costs like 250ish + dollors. I just pull the head and use my $8 compressor that I made. I have the other tool from miller and I actually prefer my tool. That and it never hurts to pull the head and inspect things.
