Single valve springs Vs. Dual Valve springs
well right now im gonna stick with stock cams but later down the road ill end up with hks 272/272
You'll be fine running the stock springs with the hks 272's. Although it never hurts to have stiffer spring pressure. Especially when the head will already be apart.
I would personally go ahead and change the springs while the head is apart. Although it is not necessarily needed for the hks 272s but if you ever decided to change to a set of kelford 272s then you will need either dual valve springs or beehive springs due to the aggressive nature of the cams that kelford produces.
Due to how many wore out springs springs I see. A new set of single springs would be a good idea.
How many miles are on the head? How old are the springs?
I like the BC1100 with stock retainers, they are an affordable sping.
But whatever sping you go with, make sure it is installed properly.
http://www.dsmtuners.com/forums/cylinder-head-short-block/420045-how-have-4g63-head-rebuilt.html
http://www.dsmtuners.com/forums/newbie-forum/341209-4g63t-valve-spring-info.html
http://www.dsmtuners.com/forums/newbie-forum/341287-how-test-valve-springs.html
http://www.dsmtuners.com/forums/newbie-forum/341028-4g63t-head-oil-port-mod.html
Hope this info helps!!
i was told the head was fairly new but there are some compression issues so im pulling it anyway to have it machined so i though i mine as well do some upgrades while im in there
The stock springs get to close to coilbind with +.050" bases with hks 272 but the BC's there's a soild .100"+ clearance. Seat pressure is around 85# with the + .050"s
  • For sale 4G63 6 Bolt ARP Head Studs
    ARP 6 Bolt ARP Head Studs $65 + shipping & paypal fees* these have been torqued onceYou must...
  • Wanted 2ga side markers
    Looking for 2ga side markers
    • Rohitter7878
  • For sale 2g 2G Fwd Thermal Research exhaust
    2g Fwd Thermal Research cat back exhaust
    • ari2gdsm
  • For sale Used Tial 44mm wastegate
    Looking to sell my used Tial 44mm wastegate. Legit Tial gate, verified by Tial. Can send...
    • Anfurnyy
  • For sale 1g 1g stock mass air. 4G63T.
    Stock 1g mass for turbo. Car ran was all stock. Hit in the rear quarter hard. 92 Tsi. Pulled...
