cory51191
- 200
- 0
- Aug 10, 2008
Leominster,
Massachusetts
i can't find any info on what i'm going to need to change or do to throw a HX35 into a 4G63 (after stage 1 mods are complete and + DSMlink)..
what needs to be changed or done to do this? the only thing i can find is sloppy pictured and people talking about denting cooling piping? someone else said that you don't need that piping. whats the best options to go with for a HX35 for performance but also fitment issues, and what else needs to be changed
. Where did you come up with the last one, jeez?
, you will want more turbo. Look for the 14b and all the parts to install a used one (new is used after it's installed, you're not going to need something new that you're going to get rid of anyway). . . Then look at maxing out the 14b: larger turbine housing, larger intercooler larger injectors, larger fuel pump, a means to tune the larger injectors.
