Besked pads change on a automatic gst
No, the only difference is AWD, if you dont have AWD all front pads are the same, fwd 1 pot, awd 2 pot,
all rear pads are the same apart from the RS which has drums,
All parking brake shoes are the same
You sure it's not early and late models. My early 92 awd has 1 piston calipers, it's also non abs but I doubt that has anything to do with it.
Mine is a GST from 1997 - Japan import (180 km/h) on the speedo.
My question was about changing pads, because its a automatic gearbox and when i push the brake it allows me to change from P-D. So i was afraid of Breaking something when changing Them. I still havent done it yet.
As far I can tell, there are 2 pistons in the caliber.
Mine too....
If you got 2 pistons then its a gsx caliper swap or gto as it came from Japan its a common swap there. But just check as it might look like 2 but have one, once you can see the back you will tell the difference easily
VR4 calipers are two piston but they also say Mitsubishi on them. I have seen two piston calipers but like I said I believe that's late 92-94
i did originally assume 2g and he confirmed so thats good for me as a guess LOL
it could well be a VR4 caliper but its not spec'd so for now im assuming stock which is single caliper for a gst
unless he posts a pic we can only guess for now
  • For sale 4G63 6 Bolt ARP Head Studs
    ARP 6 Bolt ARP Head Studs $65 + shipping & paypal fees* these have been torqued onceYou must...
  • Wanted 2ga side markers
    Looking for 2ga side markers
    • Rohitter7878
  • For sale 2g 2G Fwd Thermal Research exhaust
    2g Fwd Thermal Research cat back exhaust
    • ari2gdsm
  • For sale Used Tial 44mm wastegate
    Looking to sell my used Tial 44mm wastegate. Legit Tial gate, verified by Tial. Can send...
    • Anfurnyy
  • For sale 1g 1g stock mass air. 4G63T.
    Stock 1g mass for turbo. Car ran was all stock. Hit in the rear quarter hard. 92 Tsi. Pulled...
