Resolved Balance shaft bearings question
AustinGST98
43
4
Nov 1, 2016
East Hampton, Connecticut
Hello,
I am currently installing my Kelford BSE kit because I didn’t want to beat up the oil pump with a stub shaft.
The bearing on the back of the balance shaft from the oil pump normally is fed oil from the balance shaft itself (it’s hollow and fed from the pump), and the bearing has no hole unlike the other two.
I got my BSE kit from STM and there is a hole in all 3 bearings. Is anyone familiar with this? I feel like I may have clearance issues with this hole in the bearing. See photos below.
Wondering if anyone has experience, and if i should run the bearing with a hole or try and source a new one.
The stub shaft doesn't beat up the pump, plain and simple. I would have just gone this route.
Watch Jafro's videos where he installs new BS bearings, he explains which goes where. I believe a special tool is also required.
Ive heard it’s an issue when using helical oil gears with the stub shaft there are thrust loads and axial twisting, so I wanted to be safe. I get which bearings go where, but they sent me 3 bearings with holes in them. Just wanted to doublecheck that I’m not crazy for not wanting to put the bearing with a hole on the oil pump side where the bearing is lubed by the shaft
It might just be a call to STM and/or kelford on monday
Well if it was that straightforward then the straight cut gears wouldn’t be so sought-after. I’ve seen a lot of claims such as “On most “High” power builds people delete the balance shafts, the helical gears have “axial/side loading” issues at high rpm without the balance shaft where as the straight gears don’t have that issue with an OEM stub shaft” so typically when going with helical (as is the only available type of gears available oem) you can resolve this with the dummy shaft and bearing on the oil pump driven side.
You see this type of configuration as well with a lot of electric motors in industrial complexes, where the shaft goes from the motor, to the driven item (pump or fan) and the end rests in a bearing. Why would they not just keep the end of the shaft floating and save money on each pump or blower assembly if it makes no difference?
Lots of people just blindly follow advice they read without any kind of proof or evidence. Using demand as justification isn’t the answer. I can name a lot of things in high demand right now that aren’t worth a damn.
I've run both pump gears and never had an issue either way. I still have a straight cut set in my bin just sitting there
But to your question the back bearing where the big end sits gets oil so line that hole up. The other 2 turn 180 degrees and block the holes in the block.
That's not true. The oil pump driven shaft does not have holes. The shaft is oiled through itself. The oem bearing has no holes. That is the ops concern as he was provided with bearings and all 3 have holes when one shouldn't.
Got it... been a while for me to worry about shafts.
This would be a personal preference.
This is just my opinion, I think it's true that it may make some difference on wear with or without the balance shaft in long term or in a high rev build. But it seems it spread out a bit exaggeratedly. This is not like something happens immediately. And by seeing things from a different perspective, the dummy shaft would possibly cause some collateral damage. For instance, in case if you would break rods and if the broken rods would hit the shaft, that impact will kill the front case or/and gears for sure, wouldn't be reusable. In that case if you would't have the shaft, you may be able to reuse the front case and pump gears. So I think there is pros and cons.
Here is some info that is little known, 4g6 series 1.6/1.8L, like 4g61 or 4g67, they come with the same front case and oil pump gears as 4g63, just without the balance shafts. We know that the stub shaft we are using is from those engine. They also switched to the helical gears after 91, like 4g63. Which means the helical gears with a stub shaft was by default from factory in 91+ 4g61/4g67.
Good info. I also know why they switched. There was a TSB for a whining noise on cold startup. Not sure if this really only applied to very new cars. My 90 had it and I took it in for service many times but the techs couldn't find it until the TSB came out. The TSB also outlines interchangeability.
There is no thrust bearing on the shaft. That’s the only thing that takes an axial load. A stub shaft is just as likely to move axially as a whole shaft.
We ran stub shafts in 1300+ hp builds with a fuel pump driven off the timing belt. Zero pump issues.
Come on donnie, no one needs your logic, reason, and experience around here!
    • Detail
    • dsmmario
    • Canadian_CD9A
    • my98gsx
