Surface rust on balance shaft bearings
aaronth777
92
27
Apr 12, 2015
Dayton, Ohio
Hello all, just a quick question here. I ordered the balance shaft delete kit from stmtuned, but all 3 bearings have very visible surface rust on the outside, is this a problem? I can't feel it when i run my finger over it but thought I would ask some dsm experts. I don't want to install it only for it to cause problems
Since you are not running balance shafts, the condition of the bearings shouldn't matter since they are not being utilized. You have to remove the bearings anyway to install them so the oil gallies don't line up as to not cause oil pressure issues. When you have the bearings out, just sand them lightly and clean them up.
Okay good to know. Just to satisfy my curiosity, if I were keeping the balance shafts, would the rust be a concern? If I'm correct in how the bearing works, the bearing itself doesn't spin, right? The balance shaft just spins inside it. So theoretically if the inside surface is good then isn't that all that matters?
Yes. Is the rust on the outside of the bearing? Pictures would be helpful. I've rarely seen rust on aluminum or other bearing materials.
Here's a picture to show you what I'm talking about
No that won't affect anything as long as it's on the outer diameter. We're I using them to reinstall balance shafts, I'd probably be asking for a new set.
I think I would show the boys at STM that picture. I have never gotten anything from them in anything but new condition.
Hold up....3 bearings? There should only be two. Explain please
Even on their website it doesn't show that. Most people I know just leave the old rear shaft bearing in as it doesn't do anything. The fe9nts you have to replace to block off oil passages. Rear doesnt have a passage. Its fed through the shaft which in a delete no longer exists
He must have gotten the same "kit" that I use. They send all 3 bearings, the stub and the plug for the block. I haven't figured out why the 2 bearing "kit" is almost $30 more.
Looked at their page again, the 2 bearing "kit" has factory Mitsu bearings. If I am not using them as a bearing anyway, I don't see needing OEM BS bearings.
Yes thats the exact kit I got. As you said, theres no need for the more expensive OEM bearings if you're going for the delete. This is all good information though
