Balance shaft spacer question
Black94DSM
815
27
Jan 17, 2006
Madison Heights, Michigan
I'm using the Mirage spacer on my crank so I don't need to use the old balance shaft sprocket.
The thing I need to know is do I still use the thin plate that is between the both sprockets?
I'm pretty sure I do, as it looks like its really there to help keeping both belts from walking off (in my case only the timing belt)
Pic I found on tuners.... the plate I'm talking about is in the middle.
Also CAPS is saying there is a different part number between the 90-92 and the 92-94 plates.
Whats the difference ?
LOL Man I can't believe I even thought I didn't need it. Wow!
Thanks for bringing me back to reality guys.
1g 7 bolt bs sprocket and pate are different that 1g 6 bolt stuff. I just learned this the hard way.
