- Thread starter
- #1,326
CrackedDSM
- 5,833
- 5,732
- Dec 17, 2009
Pensacola,
Florida
Sorry you're having problems man. I know the feeling but just put your head down and truck on and you'll get it figured out.
I'm not sure what's going on with those MAP sensors though. Definitely weird. If it's doing it to both it's likely something else, although it's not impossible for both to have gone bad.
did you Reset the Direct Access tables? Take a picture of your injector deadtimes before hand so you can plug them in easier afterwards. Maybe even copy your timing table and AFR target table to an excel sheet so you can copy them back.
1: turn on closed loop. Let the car make the changes for you and manually update them later. This way at the very least the car will try to do what it needs to fuel wise to keep it running. Much less frustrating.
2: set your idle cells VE to 50 and blend into map.
3: zero you your global deadtime (figure this out for idle later on)
4: leave your global fuel where its at for now. this will likely change later on during 3rd gear stuff.
Try to start car.
The car SHOULD idle with the default DA values, minus the injector settings.
If the car idles but AFR is off, adjust global deadtime, ** NOT GLOBAL FUEL **(you'll most likely have to add fuel) until fuel trims are as close to 0 as possible. Small increments like 10usecs
I've done all of this dude. Like, what will happen is the car will idle at 10:1 AFR and die after 30 seconds. Adjusting ANYTHING VE in the idle cells does f*cking nothing, and if it does anyhting to lean it out, you can't rev the car. I've tried blending, I've tried everything.
Here's a log of me doing everything people have been asking. I put it in closed loop, didn't fix shit. Waited and adjusted deadtimes down to remove fuel, nothing. I even, for giggles, locked it back in open loop at the AFR still swings wildly from 11:1 AFR to 16:1. ON OPEN LOOP.
I'm honestly done. I'm just gonna push this car into the corner of the yard and ignore it for a few months or maybe even a year. I do everything yall are telling me to do but the car doesn't respond. At all. IDFK anymore, man.
First log: Put car in closed loop. Waited. Set deadtimes to 0. Waited. Adjusted deadtimes into negative -275 slow AF, waited.
Second log: Made drastic changes and included going WOT from Idle to catch the stutter and bog issue.
Not pictured in either log is the VE changes I made to idle, which fixed nothing. Idle sucks ass and goes rich, any throttle input car bogs and dies. I don't see how people do this, I really don't. I've triple checked everything. I even checked every nut in the exhaust system and re-boost leak checked. There is nothing out of whack mechanically that I can find. If someone could please show me on my VE map how to "blend" the cells, it would be great. Because I've tried to my limits to blend it but it takes like 38-40% VE to make it idle at a decent AFR, and no amount of blending helps it not to bog on any throttle input.
