DSMPT
DSM Wiseman
- 3,457
- 3,299
- Jun 12, 2014
Japan / Mexico,
Arizona
Sometimes I'm asked to choose rotating assemblies or look for part numbers. So, I try to make it easier to choose rotating assemblies and look for part numbers for DSM. I excerpted only DSM section from manufacturer's catalogs (As of 2020) and put those together in here. You can download it by clicking each manufacturer's name below.
Supporting vendors in this forum who sell this kind of parts most likely carry those manufacturer's products but not all vendors list all part numbers on their online store. If you don't find what you are looking for on their store, simply contact the vendor and tell the part number to order. Or you can PM me anytime. I can help you, too.
In case if there is no parts that meet your desired spec, you can customize it. Custom rods would be expensive and many manufacturers wouldn't accept only one set, so it's not easy. But simple custom pistons wouldn't be that expensive/difficult as you imagine. Generally it would take around 6~8 weeks to be completed.
I hope you find this post helpful.
* All files are listed in alphabetical order.
* Some may have typo or misprint. Such as Wiseco, JE, they categorize early EVO as 6 bolt, which is wrong. Make sure the spec before ordering.
* I marked red the section that can be for DSM if the page has other car's part numbers.
* There are more I wanted to list. Especially parts from some shops that have been supporting DSM community. But in this time I just selected the ones that probably you can easily order through most of parts stores or shops in North America.
Pistons :
- Arias (2618)
- CP (2618)
- JE (2618)
- Mahle (2618 & 4032)
- Manley (2618)
- NPR (Cast, Stock Replacement)
- Ross (2618)
- SuperTech (4032)
- Wiseco 4G63 (2618)
- Wiseco 420A (2618)
Rods/Crankshaft :
- Brian Crower (6/7 Bolt Rods & Crankshaft)
- CP-Carrillo (6/7 Bolt Rods)
- Crower (6/7 Bolt, 420A Rods)
- Eagle (6/7 Bolt, 420A Rods & 6/7 Bolt Crankshaft)
- FFWD VADER (6/7 Bolt Aluminum Rods)
- K1 Technologies (6/7 Bolt Rods & 7 Bolt Crankshaft)
- Magnus (6/7 Bolt Aluminum Rods)
- Magnus (6/7 Bolt Steel Rods)
- Manley (6/7 Bolt, 420A Rods & 7 Bolt Crankshaft)
- MGP (7 Bolt Aluminum Rods)
- Pauter (6/7 Bolt Rods)
- R&R (6/7 Bolt Aluminum Rods)
- SCAT (6/7 Bolt Rods)
- Wiseco (7 Bolt Rods)
Bearings :
- ACL Bearings Aluglide
- ACL Bearings Race-Series
- King Bearings XP-Series
- Mahle Clevite 77
Pistons :
- Arias (2618)
- CP (2618)
- JE (2618)
- Manley (2618)
- Ross (2618)
- SuperTech (4032)
Rods/Crankshaft :
Bearings :
- Mahle Clevite 77
