We're on Boost
- 3,047
- 1,468
- Aug 25, 2007
Seattle area,
Washington
No I'm talking about the push rod that comes with the slave and it pushes on the end of the fork.Sorry our you referring to the MC?
, yes I am running the rod that came with it Ok good!Gotcha, yes I am running the rod that came with it
These holes in the slave ears were probably threaded with 8mm thread weren't they?along with enlarging the 2 bolt holes a little bit.
, but once the slave was flushed up the holes on the slave to the trans didn’t line up perfectly, I could line up one ear and slide in one bolt but not the other, I found it was easiest to just bore out the 2 holes slightly with a step drill bitAhh I see. Ok thanks.So the holes actually weren’t threaded, I didn’t take a picture to prove it, but once the slave was flushed up the holes on the slave to the trans didn’t line up perfectly, I could line up one ear and slide in one bolt but not the other, I found it was easiest to just bore out the 2 holes slightly with a step drill bit
So is this mod not actually a bolt on then? I know DSM slaves are available in 3/4 and 13/16. I'm assuming the mod is the 11/16 to get a little more throw.So the holes actually weren’t threaded, I didn’t take a picture to prove it, but once the slave was flushed up the holes on the slave to the trans didn’t line up perfectly, I could line up one ear and slide in one bolt but not the other, I found it was easiest to just bore out the 2 holes slightly with a step drill bit
, you just have to do a little bit of grinding to get it to sit flush on the trans
Right?! I've got a 2 car and I'd take his for sure.That is one cozy ass garage, dude
I’m loving itView attachment 737533GOD BLESS THE USA
, in the last month or so I was working on upgrading to a 2awg wire for the alternator to try and keep the voltage up during wot pulls. So I figured I’d go ahead and drill a hole in the ole fire wall right next to where the main power came in, should work right?
, like I’ve said before this car deserves better
, anyways this ended my wrenching for the day as I contemplated selling the car and finding a new hobby. I knew to fix this I’d have to put my hands on parts of the I never intended on touching
, the ac evaporator and blower motor were doin just fine up there until I grabbed the drill
, but anyways I knew they had to come out for me to fix the harness, went ahead and pulled out the ac core as the AC in the engine has been gone for years, this allowed me to finally use my 3d printed AC delete plug from dsm3dcreations I bought a while back
go ahead and say something about it
I don't think the alternator is ever going to have much more than 100 amps coming out of it ever, even with a "200 amp" rated alternator. And most of the time it'll have less than 100 amps coming out of it.Wow, only issue with the 200amp Saturn is I believe I’d have to run 0/1awg wire? @ist dwa posted up a link awhile back about a factory looking 160amp I might try, but again, in cooler weather even on the stock harness my voltage was 13.3-13.4, and even at 13.0 AFR’s are still in the target range, so I assume fuel pressure isn’t dropping, idc’s are like 66% so everything seems like it’s fine
Hey man you rebuild s90’s right? I’m curious if you replace the shaft seals and cure the annoying “whistle” they have. My 70mm doesn’t leak at all externally, I shoot 50psi of tool pressure thru it on a blt with zero bubbles, but from what I understand it’s something internal that makes them whistle at idle, pretty annoying but other than that I think it’s a beautiful piece and I’m happy with mineI went with the 160 amp version and 0 gauge from a trunk mounted battery. In 90 degree weather with fans on is when I seen my 13.9v. Most of the time it's 14.1v.
I do rebuild them. I've done well over 100 now and have had exactly 3 people say they still whistled after I rebuilt them. One of them came from my personal car and it didn't whistle but he said it did when he got it, so I have no idea. I test them to 40 psi without issues so I don't know why those 3 still whistled. Probably 60 or more have said the rebuild fixed the whistle completely. My goal is to make them seal up and hold boost without any issues.Hey man you rebuild s90’s right? I’m curious if you replace the shaft seals and cure the annoying “whistle” they have. My 70mm doesn’t leak at all externally, I shoot 50psi of tool pressure thru it on a blt with zero bubbles, but from what I understand it’s something internal that makes them whistle at idle, pretty annoying but other than that I think it’s a beautiful piece and I’m happy with mine
. I watched the logged value of the isc position slowly fall from 120 all the way to 0 where it stayed, so I’ll still have some adjustments to make, however the car idled great the whole time!
