- 2,609
- 33
- Dec 17, 2004
East Hampton,
Connecticut
Meh, I hesitate to post this up because of the crappy time (and the way I did it), but figured i'd share a little for the 420a crowd.
Last minute chance to get out of my job and go to a rental at our local track (LVD). Cold as witches titties and no sun. Still got a little hook but lots of track wet downs (pet peeve; guys if you go to the track ESPECIALLY IF YOU HAVE A TRACK CAR put water in your cooling system. It works better than coolant and it doesn't shut down the track for an hour each time you blow a hose /end peeve). Maybe 2 1/2 hours of actual racing time.
Worked up to full race because of the cold. Second run (first lost intercooler t-bolt), warm up drive train 14.6. Third run, warm up drivetrain again (coolant on track) 13.1. Fourth run hit it a little harder 12.6. Fifth run, change shift points to stay in boost 11.4 @ 119.62 (with a 1.845 launch).
BUT, I stoopidly forgot to hit my switch to turn the water to air intercooler on. So I basically went down the track with no "intercooling" on a BW366 @29lbs. Not the best of ideas.
Just before the end of the track, I had an explosion of water and steam come up out of my hood vent. Lost the upper radiator hose. Figured I popped the HG because I didn't hit the switch, but when I got home I checked it out and it seems like the clamp just broke.
Eh, crib notes I was stupid and tried to blow up my car. Car as it sits is good for 10's, if only the driver would do it!! Dummy
MB
MB
