- Year
- 1996
- Model/Trim
- Mitsubishi Eclipse N/T
- Mods-Bolt-on
- 4-1 Headers<>GST Cat Back Exhaust<>OBX High Flow Cat<>195 Degree Thermostat<>Short Ram Intake<>Power Wire Up Grade<>Grounding Kit<>UDP<>60mm Jeep Throttle Body<>60mm Tapered Intake Manifold Port<>Battery Relocation,
- Mods-Engine
- Head Porting/Polish
- Mods-EMS & Logging
- Oil psi<>:Vac/Boost<>Volt<> OBD2 Scanner LOL
- Mods-Drivetrain
- ATX to MTX Swap<>XTD Stage 1 Clutch<>4g63 Slave Cylinder Rod Swap<>Custom Short Shifter<> Modified Trans Shifter Arm<>Solid Shifter Mounts
- Mods-Handling
- F+R+LR Strut Bar<>Custom poly Mounts<>3000gt Dual Piston Caliper<>Cross Drilled Rotors,
- Parts Wishlist
- Turbo kit Parts List+Price
T3 Volvo(Used).......................49.95
Oil feed/Return.......................35.20
FMU (Used).............................12.60
255Lph...................................98.55
- 1/4 Mile E/T
- 0.000
- 1/4 Mile MPH
- 0.000
- 1/8 Mile E/T
- 0.000
- 1/8 Mile MPH
- 0.000
- 60' Time
- 0.000
- Dyno TQ
- 0.0 lb/ft
