Anfurnyy
Supporting Member
- 1,492
- 1,910
- Jul 4, 2020
Rapid City,
South Dakota
I've got some aluminum rod questions.
R&R Rods
Im getting around to torquing my rod bolts (L19) to check bearing clearances. I have a bolt stretch gauge that i'm using, torquing in sequences and checking the stretch and retorquing if need be.
I measured an untorqued L19 rod bolt, zerod out the gauge, Oiled the bolts with 30 weight (as per instructions that came with the rods) torqued the rod bolts to incrementally to 50ft/lbs. I checked the stretch and there is about .004" variance between the 2 rod bolts. one at about .0055, and the other at .001.
I double checked my Zero point with referenced Rod bold and it was good.
I broke them both loose and retorqued them again, both to 50ft/lbs and they stretched a little more again one to .007 and the other to .003. I stopped right here with this rod.
I moved to another rod and did all the same steps but torqued them to 40ft/lbs this time and almost the same variance. One to .0055, and the other to .002..
Double checked my torque on the bolts again at 40ft/lbs and it was right, and checked the Zero with the referenced bolt and it was zero again.
I noticed that the side that seemed to be stretching more was the side with the "R&R" Branding on it. Could the orientation of the bearing make a difference or is there REALLY that much of a difference between the stretch of 4 sets of bolts?
Pictures are in order of: 1st rod measurements, checking the zero with reference bolt, and 2nd measurements.
R&R Rods
