1992 VR4 #71/1000
Purpose built SCCA DSP entry.
Just wanted to warn you before you got too much deeper into the build thread and lost all the pictures, it's already happened to a few of the guys and they are none too pleased.
I really appreciate that, it would be drag to have to redo all the photos... Do you know of any alternative hosting websites aside from photobucket?
Google photos works well. If they start charging for minimal server space and 3rd party hosting, the world is probably ending...So...
I use Imgur for my build photos (though its worth mentioning I have them all in google photos as well). As far as I know there are no limits, they even give you quick URLs for HTML, BBCode, Markdown, or direct links.
I got things back up and going with google photos (see previous page for the steering column stuff)... Photobucket has gone hawkish with old photos. My old posts still seem to retain the images, but I plan on removing all the old photos from photobucket and placing on google just in case.
Left Side Kicker Panel Replacement
This was tough. The rig I had to set up to get the shape right using the tools at had at hand was silly. If you have access to a break, this sort of bodywork shouldn't be nearly as bad as it was for me. I also learned from the moonroof the value of doing spot welds and then sealing with body sealant or bondo, depending on the location.
Finally finished up one kicker panel. Quick little recap of where I started:
_kOdp-EF3bCzShoXthfujJpyIddpBjVsHUi9Qn_a4rZWcK0k0WN-HWXOuDwllFwLar_OTJDt157FD3W20Rt=w1000-no-tmp.jpg
Did the initial cutout in two steps. I had to remove the pinch weld once I saw how bad it was:
FRbRUmK86v_mBLV7WyYxwz2xVkXe_3m-q7UdMXtoqcoLJCLEPIpMTuDphZeq0VVYuBjNXP9OPCWF9NBpRkO=w1000-no-tmp.jpg
VShEelmz9FnenpFza-3I3RoCzjae7d6AqWoo82fD-DmuVbh_qGxoeTAXhTgo0oTLsjYfIRRWD-oTvMD-cya=w1000-no-tmp.jpg
Got busy with the bead blaster (sand is still falling out of my ears several weeks later). This is a partially done pic:
zjqxNEodLFjd7gyy2N_2iTHPuxLkclEeAerZDnjfz5iWQAO7X-tCfj5Qe0enmD8SPDJ96XiO2slusfNZmXU=w1000-no-tmp.jpg
Also cut out some additional gusset metal and the primed everything to seal it off from future rust:
GW5VVcVTXWqWzTrXQhnO-bTfhHTxn5jbx7Y_kg3WL_Mpjk2HNglRmu2XvS4oIDPXFSsMiaZKN8WUdgDvwCJ=w1000-no-tmp.jpg
The pinch weld had to be replaced so I cut, bent, and tacked in some 20 gage, being sure to prime inside surfaces as I went:
o2cQrVVd-WvdhMDHXLmMDed5jsfuCrE4f3IsxoPx2p2ASs-TAg43RDjuBBHhnHdjDKIoOHGoXtjSn3_wGrE=w1000-no-tmp.jpg
kAf2fd7P3GTgGvDoWGxHZehSed6FPrNGKDXELUYALoPZ9p6xC3c1dmlP3NEY1JPm0MCvVISI5-7Q3kKeN_x=w1000-no-tmp.jpg
RwG5XM4ywTLK29p2Dh2-FbTCBLXXMczr5bJX51uZEX2SjqM_OQbeerLoXsyau84b1k8f6qUsbCdqWTKRRhl=w1000-no-tmp.jpg
Since tac welding 20 gage is the only real way to join such thin material without extreme warping, you have to seal joints somehow. I found a good seam sealer on Amazon and applied it to the appropriate surfaces:
91E-CccQEeTlHCYQDnwZaZQRZnVyya3FtuwVJixlBZ2fKYvfcdPqv5vuDrHzIVyFSWWe274DHJLCBEjGH7c=w1000-no-tmp.jpg
5BQgPvH9TMRq-V3a1VsWMGHWAqyefjlqMda2e0VXy2zw8FElp22PF6P3wkRQxiuvwVl7Ao7dWao0RUyZPTh=w1000-no-tmp.jpg
vAi5LhOY_DYT01zCzsL5_TGVxADxoMVuBk3aqF8j3LNKEYObi_cblfJU_EvcpAYks9Id8jYkUwUbNSjqL22=w1000-no-tmp.jpg
With the pinch weld replaced, it was time to start on the exterior piece. I started with some CAD (cardboard aided design... any engineers out there??) to cutout and bend up my first piece. I had an elaborate home made brake setup, but I forgot to photograph it:
-73KfmBIjfA-9HTfALovFFpkdQJacmK11KvKfyJ9GJzqpvA0NNtQuPu4qcH7AUYyeN2qFcKQ0i5GxaquMpX=w1000-no-tmp.jpg
Since the old gusset had to be removed, I devised a way to provide some support for the panel with rods:
bUfDJWmXcGuSm01VgIEv8EXeHRFq-9Fx1ijz5wtFsqeMbIoSDAA2fcPvzWUtA6D9_QC4oIZCF5hRUl_4BGC=w1000-no-tmp.jpg
After the initial tac welding, I cut, plug welded, and ground the rods flush:
VcvfZdaPByhrexL_DymJ1aS4fzD-2JZC6L-dq3Bh_eYhxDLkkDS9jAujIhy4_xCZ2YzG_jWNxz5QSgYYN8Z=w1000-no-tmp.jpg
UVC_aXJ2COXwt_jQAWOYJU3hfKY5xLWk2Fp8mZgFuL4ios0WAo-dKCeHECu_FJUXNa9VbgVTB7ksEwB5ex4=w1000-no-tmp.jpg
(definitely not my prettiest welding job):
n5aQrYvJNYLlHfe9N4D3LwGgP2zYPcJruf_QlX4LjwVJ8uHUawvqUZPG9A4tbOydhoyOQ6fe0DDND2lIQio=w1000-no-tmp.jpg
qEqANMboYHzXhPjRb4Ot4Swo5TJA-XsAb0OqdX6KSCryb3EvaJlOkb75G_sVzqJAD8TVURlMwFpt86_GvWJ=w1000-no-tmp.jpg
Then the rest gets tacked into place:
0eNhLcEmGmJ2KUomka0XkKLVa0aMPnrVum5duF5-nAvEKqsQc5eiuWLXB8ssIvgSpJqqOdXssbsfajMmp0e=w1000-no-tmp.jpg
ktdblVrUNsqRpsZ9hip-ghM7Urzjlxvw4iDqT_HOCZb3gRmpjmZfsi72Ep4gL9ScEwbNWX9KtICsFDtYT1F=w1000-no-tmp.jpg
Finally, some primer is laid down, and voila!:
RESyBAsFNje0geYa9vonLc5ucrv9aMHvX2vwD2YSM1paLRYV9CIrMDKQlQNGlxlLliDsOmJU0lfz7_Stm_K=w1000-no-tmp.jpg
Moonroof Delete (part 2)
I was also unhappy with the way the moonroof joint looked, so I went back to work on that. BTW, it was a huge mistake to try to seam weld that joint to avoid using bondo. The metal is way too thin. If you do this, save yourself the trouble of having to salvage a badly warped piece. Just tac weld it and use bondo. Anyway... pictures. Step 1 was fixing the severe warpage with a combination of hammering and yielding with a rig inside the car:
L_Xo8eYKC4KnDobVTdo-B47D-g5BGq1_sf_s6EBuWaJzXlblMeDLtO0sRcZjEUskjP1cGgvBtw0ayQdq1US=w1000-no-tmp.jpg
MsQy1Q3bnM4ElRJmXbB3iQseshufzBORA4psFY-VUmvOCJJ-WruOsB3cYmg8I-GNDbhYcm_5zL9Ev4WVLub=w1000-no-tmp.jpg
SNdxpAcI9pEGjzg5ZuH7001dBuG_yVsuY4BOZhcHtecO1Ncutxx1FkZoHuHwu3EUB0NFoQRvl787LgDd63a=w1000-no-tmp.jpg
Not perfect, but much better. Then onto the much despised bondo. Apply then sand (I'm not willing to admit how many times I applied and then sanded):
W5YnAcS9ArxYpBWpWFQvlsWkhnjHwoa1rNJKfnGjfUmBvHa_jhG-3aPZxLF-4mx1-3sDEQgksW4G7H-e1gn=w1000-no-tmp.jpg
fTvu-Blb4nGQHdNiOxJ_NcCtbNL8uWbv1Ed78llL7sbOVt02xss1jVII78xcSbkYzWIDqa5ssogjhatBmKS=w1000-no-tmp.jpg
Finished product, ready for painting. I'm much happier with this than my intial work... feather edging truly is akin to artwork, and I'm no artist. You can still see the seam now, but you have to look for it:
6kFPGkCpk5z0XbxZ6Cgj-8LX_1kkjYJwyxRTr-3s2sbpV8VxwVon9rHvQoGkf64LoxuQLvKE3BAGo3LXbsh=w1000-no-tmp.jpg
GCEMGzs7CP_3eGxrkP7Vp37iyps0spu54DFLjbtQOH-XDghN0FGXPzc1J4vTZby08dJEIM634QxeDSLg-H5=w1000-no-tmp.jpg
Right Side Kicker Panel Replacement
Last update for now; the passenger side kicker repair is well underway. Since I pretty much did the step by step writeup on the driver's side, passenger side will be all pictures. I'll update this post once more when its completely done. Again, starting from the beginning:
UGZQGEZrgvohDTkBINcNB2vKtWkrP8AksauMmJVDVupGCIJb4-1u3bTrVo_UjFq0w2prxpkfDlU-Ca6snJw=w1000-no-tmp.jpg
42_pKSAwFqeBfkXh-B-sSPjExL8tWLOX6eXCNHuNi4OpggqE92L__H1svgppwXD-nFk2-eO_J3OVuP3AzTA=w1000-no-tmp.png
Zh95ha4uM8SU0kC8y5TUEJOAVN9mG8eanTkWhD62p71ATJPPKyCrV91NxWN8LPNibjRkVgl-DuBqGBe4K_s=w1000-no-tmp.jpg
(There was sandblasting before the priming... lots and lots of sandblasting, I just didn't take any pictures)
rTp0MjDNIm_xriRZX6kAMlZaR4bRzxAc8e8hkIRwgIgOAWd6VznA_050YGhTF9AfIEzy9yCKqkXOSiwHatA=w1000-no-tmp.jpg
4dOQIObq3eyRug1PJOZSHToMt4kEVUt7eG8Ua_Ggm976lUlKLWkO1HMao246HRbNbbwiWnYuMnp4jwjTu6s=w1000-no-tmp.jpg
First repair weldment for kicker panels:
4aAUNo28dDS6oUQCoGGQd19mHVbTG8r7-y2Rsyd4z_RPmQPInLiLrjnU7luvIRDBaOUwa5KwoGmRCrkL1hA=w1000-no-tmp.jpg
Right Side Kicker Panel Box-off
Finished up the passenger side fender to kicker panel section this evening. The starting point:
mAeHOvtgq2OfpQcJvQUXW0GBRH03dqoxSTkL66yYnViAD-3E2ljuE82mBkNxm1RBTAKmvhSzF53wrKGcX7E=w1000-no-tmp.jpg
Piece 1:
wHwSYMEiiK7z89J8umKfaC6_MCIvF_DzUnxuIQ7dkBdIFxEFHqd1nyecyiE7qg1mR4Li-Ns8zG-j6IO8SKS=w1000-no-tmp.jpg
ETXrW0OnnrPCM2sG_uISn1yNCwTEG7comWDMo3HuPlvQ2-ift4cAnYeITyhG74RGQWNSS2xNSnVUqkcv1RI=w1000-no-tmp.jpg
Piece 2:
TQ89czZFJJyMjbDmfBmnqfN4iMDtbsNQq-KY8L4ufXQvSZd6W0uWffECXy-SICzekHs71X5bZjrH1-W337N=w1000-no-tmp.jpg
cPZIn5BUDTvruubqb2ibIH93cUE4qAdTQVRZex6t9e3FmN1Uu2jg8R4ME4PyLmjAAXmn0NWm6_C4Xh5ZKdW=w1000-no-tmp.jpg
Stopped welding to prime the inside:
DVGm6nFnSc5C6sqO8jljWstyyOm6pRcnk5MWd5NwcHgc2pmqUYbPY-z0_z59M0hS-WRRucWtNkxEbjajetg=w1000-no-tmp.jpg
Piece 3:
krzSsvWxkedDs6kiA6qZSwZUMFmEUvUPziFrBqZB7d9bYCzNmAz1nTMyHphqvApb3zV4PID-qxcEXD5sUSg=w1000-no-tmp.jpg
(primed the inside)
UQHccKNzmSZQfC-jxKE1kgkrolNdjCKYPFGz-r8diSBx5y63q_UVKYCfzbbQGOmlMuAx7s-ix0fAoDTWbkw=w1000-no-tmp.jpg
wwwMz1JNashUa9pbQ0detaKilDGgzcWeBIChS4IYYWcBgz-y3mHIGjgrn5T2jpFI7iDCDAFkRnV304wwziP=w1000-no-tmp.jpg
Finishing touches with some cutting and priming:
NRAk1TdJeit-96Wp3cHRRmgber-TOtcRIiKlis1WGmTsCaWGRPRzeGsqfP7WTyTwCkQNnDXJTdo54hJHxiF=w1000-no-tmp.jpg
dyXwbdWSa5q1qsgjchFybFVtbugP3QC_yqWR2iSBho_v-x2ZUsEwJplK-09mB7kd5kC_36hkQ2yYyVoNVG3=w1000-no-tmp.jpg
YiTy3yQ1I4n2VHU1FN_2_H-u5_XxWm75VanDJDlmo2ttv261D4aSVPy0bAVcvHcK4qKqmITU39LUHDhCoHi=w1000-no-tmp.jpg
Right Rear 1/4 Panel Rust Repair
I keep finding more sections of bodywork to replace. Luckily, I'm starting to get pretty good at this, so it doesn't take nearly as long as it did when I started... Both rear quarters need to be redone. I was able to finish up the passenger side this evening. It started out like this:
hOrATwN7CsFA1Tsy7x5A9b7TmLN11E7crHPOo5xL2qnv_i24I10FZaa7drsFJqiDSPUC48zBEIuRT-VNalN=w1000-no-tmp.jpg
kOsvQL7pb7gMCfbn0VuCpodbFBZf_mg5ONPrqBhVKuVv6R80u6GC7ycBnGvMErpxwIqtLFrMD0BE41-ZPSm=w1000-no-tmp.jpg
Did some cutting and gave it some wire wheel attention:
ljtnswKlHyb2TJDZvwIM0bBMtl8OGuP6j3yDhB44DGVfDee2gzMU4HYnHdLv2gFiNRcgHf-xbHITvmBUuaP=w1000-no-tmp.jpg
Added a new rust treatment tool to the arsenal to deal with areas that are really hard to reach, and where sand blasting would make a mess:
l4OS_dNMf63L4exCi6I8_4NQ0F56-nHh1ZXOMtxZHdOIffinmlnVU67_syC2sWDA8kHk5JsXkl_BtjtWaN2=w1000-no-tmp.jpg
Applied and dried. When it turns black it has done it's job:
lpYBZyGhKMYXUDyhMw_NCQt6co-4iH35PJuc3RI19MCPr37GKEbvDANFv0CJSrPlx-sAsEvdJbyAPkAhQzA=w1000-no-tmp.jpg
biUR_ymtFOhUWypQw1Plm9VNYNJ_06p7TY_jNDSyDEIAdbwPqZ_iutM0lC5ei7WUB0vcdcvD2kthIul0lh5=w1000-no-tmp.jpg
On to the familiar panel fabrication process:
vG3hRrCm5B7UB71xn8DrYcBJpM5zE1IEAAg1y5l126Mg2Kr7Xy8DvmvJt-lhY5KBSCwSpgAo_sno4n_kUAh=w1000-no-tmp.jpg
ngcx4GGWrqJisdY8V4O5BtyMTmqOjRLdTBrfD2hSohOsegIv7Y2ojOAmQqt6Nw1v_yudj1BbwuC-y84sxgD=w1000-no-tmp.jpg
tNNncVKf9OliQ0YRX5V96DIPKi3dAzmmvN51foFAxHg7tDP4lQWjVUiai8gn1P2wwomUkKfSU3FSTrSUm1D=w1000-no-tmp.jpg
zO20lT5DzNxtmiddjkGUVMnRZ94euwDrY-0jQGiWh1-j6gAoj0uw66O-HZZmwAq9N9RCZiFJpDN1JQL6TKG=w1000-no-tmp.jpg
I gotta be honest, I probably would have scrapped this after uncovering all that you've repaired. I can definitely respect the time and effort you've put into this. Keep the updates coming.
Man I'm doing the same thing but not that deep. I'm doing just enough to keep the moulding in in my 91 talon. Long term she'll be just fine props man for saving her.
The thought did cross my mind. At this point I'm treating all this work as a good learning experience. Also, due to the rather poor initial condition of the car, hopefully the GVR4 community will forgive me when I chop the wheel wells and add fender flares to stuff in some 275 hoosiers for DSP.
As of now there are only two more major patch sections, including the one I've already started on. Then it's off the the races with my anti-rust arsenal, sanding tools, and a can of primer before painting the car. I'll definitely keep the updates coming.
The repair on FUBAR definitely snowballed. Initially I was just going to do about what you're planning, but I got to work and one thing just led to another. I'll actually respect your repairs if you're able to control yourself and limit the scope of your work; it's difficult not to go to town when you see rust.
Hell yeah. Chop it up. No offense, but nobody looking for a clean Galant shell will ever be in the market to buy this thing ROFL
I say tube it up. Chop off the front clip and start going baller status. Galants don't have the best weight distribution, so here's your chance to fix that. I'd also consider fuel cells, or any of the other mods that make for a nice race car, but typically aren't done because people don't want to cut up the car.
On one hand, it sucks this thing is such a rusty turd. But on the other hand, you get to chop it up any way you like with no f***s given. Not many Galant owners have that luxury, so why not take full advantage?
Keep up the good work. I definitely ain't judging you :thumb:
I appreciate the GVR4 "right to chop" blessing from a senior member of the community :)
Finished up the driver's side rear 1/4 weldment:
2751kA4kYF9kbQEaBpgPjLiC-nPAoKatVpFfIiOaD_n1yZfEmQ1Y770WXnx6G3gK38H8ZvQmJOw7qONMQVP=w1000-no-tmp.jpg
Y8jvVRBTaNwDv7EZsjkJXXuQoBx3hMX2gRc3cIjzcJNqE2ejBD97ExOlvb06AG3tisiGAOgb2qX2AISL7TU=w1000-no-tmp.jpg
0CRdgYuyRHrhi-QZ2RnXWHEMBfIAO97h6tIAsbTMvvk8ljdqqQ5O615dXU4WctpArRq2N898v_rH0egjnds=w1000-no-tmp.jpg
1-UJ4LBeB6-exgRKMtGHjhmmm1SHo98MjTxEKiSz5uFxlDepJni5HQVOrmfzuF-MoqocXbjRcbcNByvc9hM=w1000-no-tmp.jpg
PllTuCj6U1yI9OjcqOY9BDEEbD54ED3zL1gvccAfQme09YDodV2lhyE7m1GzNQvasvPIqGebHmzsNOJK0eK=w1000-no-tmp.jpg
Now I'm eyeing up the final major body repair, which is not only rusted, but is also bent up:
muiFg74qhlB_wNAu94KRMAY18hcV69_Pm_PpD8CvNw-xuiRBaaNHW6w9rcqmy-veEiZg-metJFPZoHTFUOD=w1000-no-tmp.jpg
It's supposed to look like this (straight):
I started in on it by cutting the spot welds on the back, then had to call it a night:
E9q3hyZk0YtFhkbhwLqprm6rFA2sKaU33wWXrwO8JBOJ_B5BAQ2xuacj8U_pW5lG9qRttJWYc6NYQQHWu8z=w1000-no-tmp.jpg
Rear Fuel Tank Support Replacement
Picking up where I left off. Got the rear section out:
GqhhDTIAQA2y1MUMOgX7YREX6ENRvua8yHEpjckIj70ifZnzV1p28q_vYdUIqKoGDDWm4iURajPF-5sgyP7=w1000-no-tmp.jpg
Cleaned it up:
jYwEmp8iWsnDH-EJ4TAwX2YJ9IAjcjwr3hojbm3PccCreb7d3rpT3blE46LMcFBzImeJMOZomdnMb65wqLG=w1000-no-tmp.jpg
teEoyKrGFj1ZsmVJt8pncQqfUoD5VKO1gWLdjuboHkTJxDVc0ymyYEtkeVKBS65hkmbe8lizEkAg1rISxNP=w1000-no-tmp.jpg
Welded in some studs and some patch sections and got it straightened out:
okKV6mQw4D4zQK6W1MC6yr3vR8IVAVyYd25LQBVvtZIug-WyTYGb5D2T02RDTB1C8_ksaPN5ZxM4tQgw75l=w1000-no-tmp.jpg
Primed and welded up into place:
Xpu83fScfYTzYHa3uBMpJXuDYlef9QMcSC_1Z5839O0ZxtAWfgIoBhm0ozPyIiv-aS3khHFaxZ7vHlH_XQ2=w1000-no-tmp.jpg
Vree5mRuflq_b_PoDWUxAJVgKpp0kH_J4FfBJnOJAk2fxF_o48KHeLN0sHu62BvW7kSvLp6FDPagwSdYYYV=w1000-no-tmp.jpg
Also had some time to start on a section of the underbody. Although sandblasting is faster on the front end, I've found the cleanup afterward to be just as time consuming as more labor intensive methods. So as long as you can reach a given area, whire wheel & corroseal:
M7ZyjhxADx67wSUIJ2CII0a1HAE7fLSB4fFCPcXTQtRt_UrXoDzBkT3Q2MVjhXeH7ouqukipJtOfxRtH2jT=w1000-no-tmp.jpg
Completed rear tank support patches:
JzJVgM4sr62DPWMEB-nng6LYaUh4DJRCBrExeOckd5Vltp5dlObdEgKaLwJ3smJ46-P7H19V3EAl067IlAg=w1000-no-tmp.jpg
J30vy9kB7cqGP6KKRLTXQBB7kg4lw_Nkt6q8k8taEsZ74ewkWb0aW-gZB14ayc51K6pLqJFG5E9MMyn1_lU=w1000-no-tmp.jpg
zC37CRknYl4WZatA62xphPzkSKXYKn39_377qsMV4KN5DVyimPOKY27bT-FKiT7kSCYFY2bBC9K8j4SDCjr=w1000-no-tmp.jpg
kgkfUpMlMNid__wB2mOqMprf6PB-xO3j9neVOP0mQfUQ7iSuQL8kXA_asPQbxB15Vrslqbt8rAQc8qhX47a=w1000-no-tmp.jpg
Finished up the plug welds for the rear tank support on the inside of the trunk:
LI7kjSJdBOA7DaDPiV9jwgouVC5zh_dG7ChEonW5pGIOCuOAish-g8NDx4L_qRhkWXq3wrHHJCRNvGUk410=w1000-no-tmp.jpg
Got about 1/2 way done with driver's side rear fender well patch job:
kufc4eo2sUeZRNEAtoZiKYjQ3jlS02AGEJs4bxGEzDh0-xtlmh04bMws2L98iLvDF1q44EPTaSnIAgE8fir=w1000-no-tmp.jpg
Got about 1/2 the trunk wire wheeled and corrosealed:
haiHmia2Abtyu0IF7BYte_HoKtWkhLQ6FIaS9hnMKaT4Y-MP0qnLb3r-8pkxNw26_kBycvttdECzsvta7lc=w1000-no-tmp.jpg
xtWLAItBFyvKcTUoM_RoFQ1T7ZGwIj45sTPOtzjOJrRpAK-bhmKnd3e92jBireOhU1uINK2lZi3gWN5vEIq=w1000-no-tmp.jpg
Also got the underbody wire wheeled and corrosealed in preparation for the front tank support weldments that will have to be done from scratch:
ASEKKo77astt4qp6gqXKdh2evHK6y2UqvO6cIC_0tE2JfBg5HM_2-HtwyrtIDlwfvo4MoXIXfqyk4BCg0N_=w1000-no-tmp.jpg
cGUSMxXLkZ9Wlz0vcokn2YYa4WJ11G3ic2WQIm6zsr5F3il2Ux-gFtog3xOTb1PHL_hYNG0FnQc98YnD77p=w1000-no-tmp.jpg
Front Fuel Tank Support Replacement
This is a picture heavy update so I'm gonna have to break it up a bit. Pretty much finished the rear section of the car this weekend :). Let's start with the front fuel tank weldments. Even though I'll be going with an aftermarket fuel cell, this setup will allow me to use a stock tank if I need to:
kV9ah-xUCCmGJIUNw6viSNg_P5Qi_IG0PTCVR0RC_gY-lxPbmCRDZh5pGOXrHwxmIQoVKUGL2e0EWTzq17g=w1000-no-tmp.jpg
UHfJWUlbcvDexYet-hWuAGI_Y4wBdMQI2TrguE0pg0l7mlc2Vt9dCFwl_-sKLUaFG1V8o-NrMiGhzZkae2w=w1000-no-tmp.jpg
Got the rear section thoroughly wire wheeled and corrosealed:
88uZoJsZdZHPE6InflX9ZGDIx485TTws8zjAWuIExwm8NwMm7CxYj5qAVyWLvVHFpQ5ehntrrBHCHi_IGAA=w1000-no-tmp.jpg
KUfmVaLhhPzLzWdGHMYo_Ym0d1QsQrwViJMTkrkFFM5pWirHCBSY8rDDvorl71WHpSbUYY5S8PSMliHMNNA=w1000-no-tmp.jpg
  • Wanted 6 bolt NT water pipe
    • chrisman287
