shdwmsk
5+ Year Contributor
- 54
- 73
- Nov 1, 2019
Ramsey,
Minnesota
Drivers headlight doesn't retract, goes up fine when manually retracted.
Already tested the following per the Service manual pg 8-244/245 and are working as they should:
Headlight switch
Passing Control relay
Pop-up Motor relay.
Have also replaced the motor with one that worked on the bench. The one I removed also worked on the bench after removal.
Replaced the capacitors in the Passing Control relay today and the drivers head light still does not retract. No corrosion, only slight discoloration on the board holes for C3 and R6. Have pictures, can post them if you need to see.
So I started checking plugs with a multi meter.
I do not get power to pin 5 of the drivers headlight motor harness plug. Also do not have continuity between pin 5 of drivers and passenger plug. I do have continuity between the passenger side pin 5 and pin 2 of the passenger control relay (PCR). Looking at the circuit diagram, I should have continuity between all 3, both pin 5's and pin 2 of the PCR. Correct?
How is this wire routed inside the body harness? The circuit diagram looks like after the PCR, it goes through the body harness plug C-72, then to passenger side headlight motor plug, then branching off to the drivers side. Is this the correct routing?
Headlight switch
Pop-up Motor relay.
